exhaust - Ford Powerstroke Diesel Forum
Old 01-28-2008, 02:54 PM
exhaust
Installed new 4'' mbrp- turbo back today! Install was easy & the look & quality is awsome. Sounds good too. I just have one question, my pyro. probe was in the down fall pipe. It was held on there by a hose clamp. I need to know where to find the right fitting to put it in the manifold.
Old 01-28-2008, 03:08 PM
Send a message via MSN to pinkfloyd
here's a site that has a ton of info on that stuff DieselManor - Installation Sheets hope this helps
Old 01-28-2008, 03:24 PM
International Threat
That's the normal clamp on style for the downpipe.
You can get pyro's from most vendors that sell gauges... let us know how it goes!
Old 01-28-2008, 03:28 PM
I looked at this site that pinkfloyd sent me--DieselManor - Installation Sheets-This says put the pyro behind turbo. Is this correct? I was told not.. Just want to make sure I'm doing the right thing.
Old 01-28-2008, 03:33 PM
no you drill and tap your exhaust manifold 1/8 npt.
Old 01-28-2008, 03:37 PM
Thats what I thought. Just wanted to make sure. I'm new to the diesel scene. Thanks for the help.
Old 01-28-2008, 03:40 PM
that's the way I did mine just make sure you take your time and start with a small bit and work your way up to keep the shavings small. tap the threads then use a shopvac to suck out any shaving that may have gotten in there. I did it this way and have absolutly no problems with it.
