17* of 15* hpop? - Ford Powerstroke Diesel Forum
Old 01-28-2008, 01:23 PM
17* of 15* hpop?
i see this around all the time, what exactly are they? how are they better over the stock pump.
Old 01-28-2008, 01:50 PM
7.3L Powerstrokes came with either a 15 degree HPOP or a 17 degree HPOP. HPOP stands for high pressure oil pump, and it is what makes our fuel injectors work. The 15* pumps were found in the OBS trucks 94-97 and the early 99's like mine. The 17* pumps were found in the late 99-03 7.3's and are a better pump beacuse they flow more oil than the 15*. Your truck should have a 17* from the factory.
Old 01-28-2008, 01:55 PM
would one off of a newer 7.3 fit on an OBS
Old 01-28-2008, 01:58 PM
yes they are 100% interchangable
Old 01-28-2008, 02:04 PM
is there any thing that you have to do to make it fit or will it bold right up and would it be a good up grade if i was to run small injectors.
Old 01-28-2008, 03:14 PM
John Wood Nut Swinger
To upgrade an OBS to a 17* HPOP pump you also need a HPOP reservoir from an early99-03.
It will run up to hybrids injectors(230-260cc)
Old 01-28-2008, 03:57 PM
Do you have to change anything on a early 99? Or just bolt it on?
Old 01-28-2008, 03:59 PM
Early birds just swap the pump. Nothing else needed except a new gasket.
Old 01-28-2008, 04:05 PM
Ok thanks, I got a 17* pump, just waiting on a good time to install it.
Old 01-28-2008, 04:34 PM
so all i would have to do is get one off a newer 7.3 and just get the resivor. and were is that at. im not to sure on anything on the newer trucks.
