higher egt? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 03-29-2013, 11:05 AM Thread Starter
Carpenoctum's Avatar
higher egt?
I just finished installing a new GT38R and did the ebpv delete. It already has the fx'r at 68 psi at idle, 4 inch exhaust, a DP 6 position Chip, and a afe cold air intake. The Ex runs great but on the upper two chip settings I'm actually getting a little more black smoke and a higher EGT under load than before. It's hitting almost 1300. The red line is hooked up and I'm running a zenner as a Boost fooler on the MAP. Any thoughts?
Carpenoctum is offline
post #2 of 10 Old 03-29-2013, 11:18 AM
jesilvas's Avatar
Quoted: 2 Post(s)
You have an exhaust leak(s).
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 10 Old 03-29-2013, 12:04 PM Thread Starter
Between the manifolds and the Turbo? How do I check? Get under it while idling...
post #4 of 10 Old 03-29-2013, 12:25 PM
Quoted: 3 Post(s)
or a boost leak
2000 DRW CC 7.3
Exterior: 08 Exterior Clone, 22.5's
Engine Mods: GTP38R WW2, 5 inch exhaust,T500, 6637, TW tunes,DI Up pipes, 6.7 fuel pump fuel system.
Trans Mods: 6.0 trans cooler, JW Valve body,Billet triple disc converter.
Sound Mods: 7" flip out tv, 3-way speakers all around, 12" sub, 500 watt amp.
Misc:dieselsite coolant filter, max ac assist, BRV, IHD,gauges, CCV
Next up power rear window
campbellflage is offline
post #5 of 10 Old 03-29-2013, 01:38 PM Thread Starter
I couldn't find any exhaust leaks and I'm getting 20 plus psi on the edge gauge. That's the most it can read with the diode. I've often thought that i migh worn causing marginal hpop pressure. could that cause a poor fuel burn?
post #6 of 10 Old 03-29-2013, 01:41 PM Thread Starter
Worn injector poppets. Oops. I do love the sound of the 38R!
post #7 of 10 Old 03-29-2013, 02:46 PM Thread Starter
Note to self. Recheck all clamps twice. Tighten band on orange intake boot. Check! Duh! Time for another test drive!
post #8 of 10 Old 03-29-2013, 02:49 PM
jesilvas's Avatar
Quoted: 2 Post(s)
: no boost leaks huh?
4R100, 2wd
330,000 + miles
jesilvas is offline
post #9 of 10 Old 03-29-2013, 03:01 PM Thread Starter
Lol! Yes you were right. Runs even stronger burning that black smoke in the motor! Thanks!
post #10 of 10 Old 03-29-2013, 03:09 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Good thing that's all it was.
4R100, 2wd
330,000 + miles
jesilvas is offline
