Single Shot Injectors - Ford Powerstroke Diesel Forum
Old 01-26-2008, 01:53 PM
I just installed a set of beans diesel's stage two single shot injectors and would like to know if anyone else has a set and if so whats your truck idle like. They custom burned my chip, but it still dosen't seem right. All the setting feel the same to be beside high idle and what i thick is the stock position.
Old 01-26-2008, 02:12 PM
did you get all the air out?
Old 01-26-2008, 02:54 PM
I've drove the truck about 25 miles, so I would thick it is all out.
Old 01-26-2008, 03:00 PM
John Wood Nut Swinger
doese it start normal or does it take a few extra cranks?
If it takes a few extra cranks(not normal), keep driving it until it idles normal. I had to go over 50miles to get it to run right. Fast accelerations and normal stop and go will pump out all the air the fastest.
Old 01-26-2008, 07:52 PM
It starts good, it just idles rough. I didn't know if it was a problem with the chip or just the nature of the single shot injectors. They had trouble burning the chip and I can't tell the differnce in the programs so I didn't know if that was my problem.
Old 01-26-2008, 08:34 PM
Those tunes are from TW. I would try calling Tony and see if he knows what is up.
The same thing has happened to another .org member. He can't get his truck to run worth a darn either since his stage 2's and TW tunes.
Old 01-26-2008, 08:39 PM
am i missing something.....or is his sig wrong howard??? it says DP tuner...
Old 01-26-2008, 08:51 PM
He said he got the chip burned by Beans. Bean does not sell DP tuner any longer, at least that is what Bean told me on the phone a month or two back. He said he uses TS for generic stuff and TW for the good stuff. This will be interesting to find out what is on the chip for tunes.
Old 01-26-2008, 08:54 PM
Send a message via AIM to TW451
Ryan told me a few weeks ago that they weren't using TW's chips all the time anymore. Said they are burning some of their own now.
Mine idled a little rough on the way home from Beans, but cleared out fine by the time I got home. About a 40 mile drive and I only got stage 1 injectors.
Old 01-26-2008, 09:04 PM
Cynic
And add the fact that DP tuner stuff is all over his website.
