cheapest and safest temporary levelling method? - Ford Powerstroke Diesel Forum
Old 01-26-2008, 12:28 PM
I am buying new wheels and tires (35 x 12.5 r 20) and would like to lift the front of the truck so I could mount them for the time being until I buy a 4 inch lift. I was wondering if these mini leaf packs from Truxxx or Donahoe are safe. It seems they are basically a block and from what I've heard thats pretty unsafe on the front of a leaf sprung vehicle. I have a set of old leafs lying around and was wondering I could make something out of those.
The other option I was considering is making a set of drop shackles as I work at a metal fabrication plant. It seems simple and at the end of it I could keep them in case I wanted to go a few inches higher in a couple years. Is there more to making them than meets the eye or does anyone advise against it. Let me know what you guys think
Thanks
Old 01-26-2008, 01:47 PM
You can get a set of shackles off ebay to raise your front end up about 2" for around $70 bucks. I've got a set on my truck along with a 4" lift and it rides good and there easy to install.
Old 01-26-2008, 01:51 PM
Send a message via AIM to 4everlearning
They are easy to make. just keep in mind that if you want 2" of lift you have to make them 4" longer then stock. 3" lift = 6" longer and so on
Old 01-26-2008, 03:00 PM
Powerstroke Techie
Here is a pic of the front hanger brackets I made for mine, been running them for 3-4 years and they work and look great.
Old 01-26-2008, 07:38 PM
Location: Southeast Texas, right where Hurricane Rita hit!
I went to my local spring shop and he was able to rearch my springs as well as add a leaf to get my front end up. I am running 325's on 20's and they should be the same height as yours. The whole deal was $250.
Some stated the ride would be rougher and I really can't tell a difference. My tire guy did have to knock a touch off on the lower corner of the bumper(metal) and just cut a slant on the plastic and I have no rubbing.
Old 01-26-2008, 11:12 PM
Looks a bit nicer and more factory if you just space the bumper out about an inch.
