Mating driven diesel filter to irate RR - Ford Powerstroke Diesel Forum
post #1 of 7 Old 03-26-2013, 11:42 AM Thread Starter
will a post pump filter kit from driven diesel hook up to Irate's RR without too much hastle?
Superduty is offline
post #2 of 7 Old 03-26-2013, 03:22 PM
Quoted: 17 Post(s)
Send a message via AIM to rufushusky
Are you running a bowl delete or did you keep the factory fuel bowl?
What pump are you using?
2002 F-350 4X4 ECLB 7.3 4R100 6637 filter w/ RiffRaff cover, 08 diff cover, 203* T-stat, HPX, Stancor Relay, 6.0 trans cooler, Zone leveling kit, 8'6" Western Ultramount
Sold: 04.5 Dodge Ram 2500 5.9 CTD, Reg Cab, 48re
rufushusky is offline
post #3 of 7 Old 03-27-2013, 11:58 AM Thread Starter
stocck pump. Yes bowl delete
post #4 of 7 Old 03-27-2013, 11:59 AM
01Crewcab7.3's Avatar
I have the same question haha.
Sent from AutoGuide.com App
Tim
2001 F-250 Lariat CCSB, 4x4, ZF6 249k, 6.5" Procomp lift, 37" Toyo M/T's, 20" Fuel Hostages. PIS 160/30's, PHP Hydra, 6637, 4" exhaust, Tank mods, ISSPRO's, 08+ mirrors/tailgate/tail lights, M12000 winch.
01Crewcab7.3 is offline
post #5 of 7 Old 03-27-2013, 12:12 PM
Quoted: 17 Post(s)
Use the quick disconnect to AN fitting that I think comes with the Strictly kit run that to the fuel filter head and run the other line up whatever you are using for a distribution block... what are you using? Are you using Strictly s bowl delete block or Irate or DIY?
If your using strictly's kit you simply thread the thread the fitting right to the delete block. I don't know what they use, looks like AN. If you are DIY'ing it with a NPT fuel log or something you need to get an AN to NPT adapter but it shouldn't be that bad. Summit or Jegs will have the fitting.
post #6 of 7 Old 03-28-2013, 07:09 AM Thread Starter
i want to use Irate's RR with bowl delete with Strickly's post pump filter...
post #7 of 7 Old 03-28-2013, 07:17 AM
Quoted: 17 Post(s)
You will need to find out what Irate uses as a fuel distribution block and then it is simple as getting an AN to whatever the ports are on the Irate block. I would guess they are either NPT or AN but I would double check with them. You might need a 90* fitting since the Strictly (SD) kit has a 90* hose fitting. I would also double check with SD about the hose and fitting size they use on the post pump kit, it looks like -6AN (3/8th) but I am not positive.
