TS chip 140 hp??
i just installed my ts 6 pos chip with stock, high idle, anti theft, 75, 100, and 140. 75 works great! 100 ehhh not so much. if i touch the throttle my rpms skyrocket instantly and when i try to let the clutch ease in it sounds like its ready to die. once its in gear works ok ish. if i floor it it has no response. but it does smoke up everything behind me. once i flip it to 140 hp.... it wont even start! does my truck have to get used to the chip or what?
THankS for any info in advance! |
maybe your contacts on the pcm didnt get quite clean enough or somethings wrong with ur chip?
That does not sound right to me. Mabe call who ever sold you it and see what they have to say. anyway here is a bump so a tech will see it.
I would make sure you have all the silicon cleaned off good enough on the pcm and go from there....
Yeah when i did mine it wouldnt start at all, and i just didnt have it cleaned nearly well enough, my truck truns great in every setting. good Luck
if it starts on other settings but not that one, i'd say it is a chip problem. Check the contacts, but also be aware there have been some ts chips with problems lately. i had to send mine back because it was missing a resistor apparently and would start only sometimes, only on certain settings, never on the same setting. my chip had a dark blue board and the other side is white silkscreened with a black ts logo, and another member here had a similar problem with the same colored chip.
