Turbo improvements - Ford Powerstroke Diesel Forum
post #1 of 28 Old 03-26-2013, 05:59 AM Thread Starter
Turbo improvements
Hey all, So i will get right to it. I am getting new injectors and going through some turbo rebuild.
Stock turbo, rebuild kit...EBPV delete housing and pedastal, WW2, and I got a BD larger wastegate...however I am looking at Riffraff diesel's 1.15 A/R non-wastegate housing and possibly a new compressor side housing.
Question is: is the non-wastegate housing a good idea? or does the wastegate provide some sort of safety function esp running larger injectors. A larger compressor side housing seems like a no-brainer good idea, and so did the exhaust housing, however, will eliminating the wastegate have any negative effects? Would you recommend a larger wastegate and keeping the stock exhaust housing or going with the larger exhaust housing?
Housing I am talking about is: Riffraff Diesel: Garrett 38R "BB" 1.15 A/R Exhaust Housing
jsot54 is offline
post #2 of 28 Old 03-26-2013, 06:56 AM
Joel's Avatar
Quoted: 10 Post(s)
I'm running a van turbo, which has a 1.15 exhaust housing and it spools SLOW.
Truck runs real smooth and has basically no EBP at 65 mph though so I like that.
Fill out your sig with what's already done to your truck. Then we can help you better.
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #3 of 28 Old 03-26-2013, 07:10 AM
Quoted: 3 Post(s)
Didn't PHP prove that you can make more HP with the 1.0 housing on the 38R, I would save your money on the extra housing.
2000 DRW CC 7.3
Exterior: 08 Exterior Clone, 22.5's
Engine Mods: GTP38R WW2, 5 inch exhaust,T500, 6637, TW tunes,DI Up pipes, 6.7 fuel pump fuel system.
Trans Mods: 6.0 trans cooler, JW Valve body,Billet triple disc converter.
Sound Mods: 7" flip out tv, 3-way speakers all around, 12" sub, 500 watt amp.
Misc:dieselsite coolant filter, max ac assist, BRV, IHD,gauges, CCV
Next up power rear window
campbellflage is offline
post #4 of 28 Old 03-26-2013, 09:15 AM Thread Starter
Im not sure about the PHP determination. I am just unsure about removing the wastegate all together or using the larger BD wastegate with a stock housing. I have about set on getting a larger compressor housing. Just curious if EGT issues dictate I should get the exhaust housing minus wastegate.
jsot54 is offline
post #5 of 28 Old 03-26-2013, 09:32 AM Thread Starter
So I found someone running the stage 3 hybrids (250cc) same truck as mine. Has the gen 2 WW and 1.15 exhaust side housing saying the turbo is keeping up great no surge or exhuast brake feeling. Looks like thats what I will be going with and save the cash of the compressor side housing.
2003 F250 ext cab short bed 7.3L manual 4x4
6637 intake, MBRP 4'' exhaust muffler delete
Strictly Diesel Reg return fuel system, hitch mod, CCV mod, walbro high capacity fuel pump Pre and Post pump filters
SCT livewire and TS 6 position chip tunes done by Matt @ GearHead
Gen 2 WW, 1.15 non-wastegate housing, upgraded compressor housing, EBPV pedestal delete, new exhaust wheel and turbine,
stage 3 hybrids(250/100)
4in all spring Icon lift
jsot54 is offline
post #6 of 28 Old 03-26-2013, 09:47 AM
Quoted: 3 Post(s)
Ill have to find the thread but I am pretty sure that during the testing, that boost was lost, and like 40-50 hp was lost with going with the bigger exhaust housing. EGT's and backpressure was negligable.
2000 DRW CC 7.3
post #7 of 28 Old 03-26-2013, 10:07 AM Thread Starter
yeah if you can find the listing of data backing that I would be greatly appreciative. Seems like the wastegate generally is useless for those larger injectors. So maybe at stock or small injectors that housing excells but at the larger injectors the bigger 1.15 does. I am not sure at all though. I am going to test drive the rig today to see if I like the performance with the setup I listed.
jsot54 is offline
post #8 of 28 Old 03-26-2013, 10:26 AM
Quoted: 3 Post(s)
here you go.
Garrett 38R 1.0 vs 1.15 dyno test - PowerStrokeArmy
2000 DRW CC 7.3
post #9 of 28 Old 03-26-2013, 10:49 AM Thread Starter
hmm that is very interesting. It seems the bigger change in that data is from the compressor wheel. When you look at it whichever housing that has the stock wheel that one generates more boost. So really the HP is greatest in with a stock wheel and 1.0 housing in that data. although when you look at the boost the 1.15 housing with stock wheel had tied for same max boost. The lower HP seems strange to me.
jsot54 is offline
post #10 of 28 Old 03-26-2013, 10:54 AM
Quoted: 3 Post(s)
I can't see why it would be biased in any ways, its not like he makes a housing for the turbo. I have read on other posts pretty much the same information, that the housing is over rated and not really much of a gain. I was gonna buy one as well, but just went with the ww2 and waitin on injector money.
2000 DRW CC 7.3
