exhuast install, need some tips.. - Ford Powerstroke Diesel Forum
Old 01-25-2008, 12:14 PM
hey guys, im puttin on my 4inch striaght pipe exhuast tomorow, and i was wondering if there are any good tips i should know, before i screw something up, any one know a good torque spec to tighten the clamps, and the v band clamp from the turbo to also?
Old 01-25-2008, 12:17 PM
IU Hoosier Fan
don't know about the tq specs.. but when I done mine I had a hard time getting the down pipe pushed up into the engine compartment.... the only way I was able to get it put in was with a ratchet strap... I had to put it on the transmission to pull it over a 1/4 or 1/2 of a inch to make it go with no problem.... once I did that it was nothing.... good luck
Old 01-26-2008, 02:11 PM
well, afte r along day of cold and avrigation i got my exhuast one, its not as loud as i wanted it to be, but it does sound saweet, it wistles like a jet too!! thanks everyone
Old 01-26-2008, 03:08 PM
got a question i just put on my 4inch straight pipe today , was wondering if there is any way to check for leaks? also new to this but is it normal to have it loud in the cab now? and feel the truck rumblin?
Old 01-26-2008, 03:13 PM
i just crawled under my truck and felt for air on all the fittings,
Old 01-26-2008, 03:15 PM
Rob Rob is offline
your gonna have some sound difference. you may feel a little of the rumble inside too. i do. not a big issue.
Old 01-26-2008, 03:16 PM
i did that dont seem to feel any but would it be possible to put some soapy water on there to see if it bubbles? also is it loud in the cab and can feel the vibration for you as well?
Old 01-26-2008, 03:17 PM
to me it seems def a lot louder inside the cab and vibration but im assuming this is normal
Old 01-26-2008, 03:21 PM
Rob Rob is offline
it is normal. if you have any leaks you will know within a short amount of drive time. just look for little black streaks around the slip joints. if its leaking it will show up!
Old 01-26-2008, 03:24 PM
ok and if those streaks show up then i just adjust and tighten her down some more?
