ts chip problems - Ford Powerstroke Diesel Forum
post #1 of 10 Old 03-25-2013, 06:12 PM Thread Starter
ts chip problems
I have a ts 6 position chip installed on my 02 7.3 and seems to having an issue.... It supposed to be stock high idle 50 75 100 110 tunes or something really close to that anyway it seems that the first 4 spots are high idle and only one hp tune and it's not that much any ideas why it's not working properly FYI I've scrubbed the terminals very well
chiefson is offline
post #2 of 10 Old 03-26-2013, 11:06 PM
dentexpowerstroke's Avatar
Are you positive it was tuned for the right pcm code?
Sold 2001 f250 ccsb 4x4 400/400, dual terminators, swamps 80mm bfh, headers, bts and all the usual supporting mods. 715hp fuel only.
06 f250 ccsb king ranch
12 f250 lariat ultimate
dentexpowerstroke is offline
post #3 of 10 Old 03-27-2013, 11:21 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
May have cleaned to much! if you see copper its time to re-solder
CT Performance, Inc. is offline
post #4 of 10 Old 03-27-2013, 05:48 PM
I just did one in my truck, use the scotch brite they supply you with and clean the solder to copper, make sure you dont go to deep. Mine took a few try's to make a good connection
2000 f350 single wheel, zf6, 4 inch exhaust muffler delete, sb cold air intake, wicked wheel 2, Ts performance chip, international bellowed up pipes, 8 inch lift, 37 inch tires. Sold
2006 f350 ccsb, 4 inch turbo back exhaust, sct tuner.
Southernways is offline
post #5 of 10 Old 03-27-2013, 07:59 PM Thread Starter
I was gonna try that one more time before I call ts
chiefson is offline
post #6 of 10 Old 03-28-2013, 05:10 AM
Quoted: 3 Post(s)
DO NOT GO TO THE COPPER, OR LISTEN TO NUBBIE'S WITH 2 POSTS!
All you have to do is clean the wax coating off...thats it...
post #7 of 10 Old 03-28-2013, 01:21 PM
Thanks Dick
I have only been doing this for years and have never joined a forum just for this issue, call ts, this is exactly what he told me to do and the only way it would connect with ecm
post #8 of 10 Old 03-28-2013, 01:44 PM
Quoted: 3 Post(s)
Well still doesn't change that its wrong...so many post have been over this over the years and guys removing the solider only to have to re solider it to be able to use the chip.
No where in their instructions doe it say to remove the solider...I've been selling and installing TS chips for years...
By the way my name isn't Dick...
post #9 of 10 Old 03-28-2013, 06:59 PM
Tell that to the guy at Ts performance, mine would make no contact with solder on it period. I went back and forth with them about and his exact words was to get rid of the solder.
But it's ok big man, you win this one
post #10 of 10 Old 03-28-2013, 07:28 PM
Wannabitawerm's Avatar
I've heard this over and over. Went to silver, no dice. Tried several times. Nothing. Went to copper, runs like a champ, no problems.
Sent from AutoGuide.com App
Wannabitawerm is offline
