Upgrade Calipers - Ford Powerstroke Diesel Forum
post #1 of 18 Old 03-25-2013, 03:40 PM Thread Starter
greenguy103's Avatar
Upgrade Calipers
Hey I am new to the site and have a stock 4X4 7.3 2000 Ford f-250. I know the calipers on the rear are smaller than those on the front. I was wondering if there was any upgrades or something I could to do to get bigger calipers and pads on the back.
Thanks,
Jacob
greenguy103 is offline
post #2 of 18 Old 03-25-2013, 03:42 PM
7.34ever's Avatar
Quoted: 2 Post(s)
Feedback Score: 9 reviews
Welcome to the org.
I'm sure someone will chime in with an upgrade for ya. Good luck.
12TH Man
Live in WA or OR??? Check out these links.
7.34ever is offline
post #3 of 18 Old 03-25-2013, 06:08 PM
Tj Krawler's Avatar
Yes... There are upgraded brake kits for our trucks. You would need 20"+ rims though. The big brake kits, for front and rear have 16" rotors and 6 piston calipers. It's been a while since I've priced them, but IIRC it was close to $7,000.
Most people who want an upgrade go with Powerslot (slotted, not drilled) rotors and Hawk pads. MUCH cheaper option.
Alan
2000 F-350 CC LB DRW 4x4 XLT Auto
- Intake
- Exhust
- ScanGauge
Tj Krawler is offline
post #4 of 18 Old 03-25-2013, 06:09 PM
Quoted: 3 Post(s)
you could do an 05+ axle swap.
2000 DRW CC 7.3
Exterior: 08 Exterior Clone, 22.5's
Engine Mods: GTP38R WW2, 5 inch exhaust,T500, 6637, TW tunes,DI Up pipes, 6.7 fuel pump fuel system.
Trans Mods: 6.0 trans cooler, JW Valve body,Billet triple disc converter.
Sound Mods: 7" flip out tv, 3-way speakers all around, 12" sub, 500 watt amp.
Misc:dieselsite coolant filter, max ac assist, BRV, IHD,gauges, CCV
Next up power rear window
campbellflage is offline
post #5 of 18 Old 03-25-2013, 07:35 PM
Re: Upgrade Calipers
I'm interested as well in looking for new rotors all around and new pads. Car to explain slotted rotors and the benefits?
Sent from my VS930 4G using AutoGuide.Com Free App
01 F350 dually CCLB Lifted 7in
WW Gen2
6637 w/zoodad
6pos tuner canned tunes
isspro ev2 pyro, boost, trans temp
4.5" custom stack
AIH delete
CCV mod
22.5 rims on there way
ventryjr is offline
post #6 of 18 Old 03-25-2013, 08:38 PM
7.34ever's Avatar
Quoted: 2 Post(s)
Slotted and/or cross drilled rotors dissipate heat much faster than your stock rotors so they stop you faster and don't warp
12TH Man
7.34ever is offline
post #7 of 18 Old 03-25-2013, 09:13 PM
Tj Krawler's Avatar
Beat me to it. Powerslot doesn't make rear DRW rotors though. There are a few places that do.
I see you're from WNY... We have a NY chapter if you want to check it out. Empire State Strokers - Ford Powerstroke Diesel Forum We might even be having a little get together in the WNY area next weekend.
Alan
- Intake
- Exhust
- ScanGauge
post #8 of 18 Old 03-25-2013, 10:41 PM
Sgt90's Avatar
$7000 for brakes???????????? wow! i was looking at upgrading as well...slotted rotors were around $200/wheel for midgrade...low grade were about $90/wheel....
2003 7.3 ccSB Lariat
~155k
5" Straight Pipe
20" XD's
37" Nitto Trail Grapplers
After-market waste gate actuator
TW 6-Pos Tuner
K & N Intake
Sgt90 is offline
post #9 of 18 Old 03-26-2013, 06:31 PM Thread Starter
Hey thanks so much for the help every. I'll probably just start off with drilled and slotted rotors and leave it at that for now.
post #10 of 18 Old 03-27-2013, 07:41 AM
Quoted: 134 Post(s)
Feedback Score: 3 reviews
NO,,, Drilled/Slotted rotors have nothing to do with cooling, and "finned" rotors don't Warp anyway....
The purpose of the holes or slots is to Vent gases that are produced, under heavy braking, and "push" the pads off the rotor surface. IMHO, slotted are as good for venting for our trucks and eliminate the cracking that can occur with holes.
Brake pulsations are caused by the difference in the rotors surface, as the pads slide on them, "gripping" better/worse. Cutting the rotors gives you an even surface so it eliminates the pulse, but there was no warp. Proper Bedding of the surfaces prevents the problem in most cases.
REAR Brakes, in our unloaded trucks, aren't doin' $hit in the first place don't waste your money. They suffer more from corrosion, because they are so "unworked", then anything else (the inside of the rotors, against the dust shield stays lumpy & crusty because it doesn't get used enough (unless you drive a lot of miles or tow/haul weight))
The Fronts always do the majority of the work, especially empty, and if you want to improve braking that's where to do it (although with good tires/pads/rotors our brakes are really pretty good!)
NoRalPh is offline
