Wicked wheel install questions. - Ford Powerstroke Diesel Forum
post #1 of 11 Old 03-25-2013, 09:38 AM Thread Starter
Wannabitawerm's Avatar
Ok. First my mods; 6637, 4" turbo back, ts 6 pos chip, zoo dad and a few other that don't really pertain. (Gauges, lights, etc) since I'm pulling the turbo, my plan is to clean the ebpv,(not planning on a delete) cleanin and polishing the intake pipes, and a general cleanin up of the engine bay. I also purchased a boost fooler from dieselsite just in case. My question is, what prep work needs to be done first? I'm planning on soaking the bolts to help them loosen of course but, I wanna pick your brains before I do. What would you guys do, recommend, replace, etc while in the process? I also plan on having my canned tunes custom tuned after the install. Hit me guys. I'm ready.
Sent from AutoGuide.com App
Wannabitawerm is offline
post #2 of 11 Old 03-25-2013, 10:45 AM
350 ONE TON's Avatar
Why do you not want to delete the EBPV? I deleted mine and couldnt be happier. No more oil leaks, sounds better, and runs a little better. If your taking it off anyway just delete it IMO. Sounds like your on the right track with things though
2003 F250 XLT 6Spd 4X4 ECLB 4" lift 4" turbo back duals, AFE Stage 2 XP, superchips flashpaq (gone soon I hope) GTP38R, Gutted EBPV
350 ONE TON is offline
post #3 of 11 Old 03-25-2013, 11:17 AM Thread Starter
I have a few weeks to decide so I will look more into it. I'll assume I'll need a new pedestal? Also, should I mess with the wastegate at all?
post #4 of 11 Old 03-25-2013, 12:01 PM
I used the non EBPV pedestal and outlet. Both from riffraff. As far as the waste gate that's a wide open topic. Run it and see what boost you make and go from there. Some guys like to disconnect them some crank them tight and some don't mess with them. It's something you'll just have to experiment with.
post #5 of 11 Old 03-25-2013, 07:39 PM
Re: Wicked wheel install questions.
I didn't have to soak any of my bolts in my 01. As far as I can tell the turbo hasn't been pulled ever. 207xxx miles. The only birch was the uppipe to turbo connection. A little fused together. Southern truck tho. Also have you considered a ccv mod? When I pulled my intake it was full of sludge from the ccv. I think it's a worth while mod.
Sent from my VS930 4G using AutoGuide.Com Free App
01 F350 dually CCLB Lifted 7in
WW Gen2
6637 w/zoodad
6pos tuner canned tunes
isspro ev2 pyro, boost, trans temp
4.5" custom stack
AIH delete
CCV mod
22.5 rims on there way
ventryjr is offline
post #6 of 11 Old 03-26-2013, 07:34 PM
Silver200273L's Avatar
Depends on where you live. I have thought about delete EBPV but I live in cold weather and have EBPV help close the valve and warm up the engine faster. If you live in warm weather then u should delete it.
DP Tuner
Dieselsite Wicked Wheel II
5" Straight Pipe
6637 DIY Intake
Riffraff Intercooler Boots
Riffraff CCV
Harley Davidson Headlights Conversion
05-07 Grille
2.5 Leveling Kit
33" BFGoodrich All Terrain
LED tail lights
Billet Grille
Line of Fire
Silver200273L is offline
post #7 of 11 Old 03-26-2013, 08:07 PM Thread Starter
In northeastern Ohio so I definitely experience some cold temps.
post #8 of 11 Old 04-02-2013, 04:54 PM
RexF350's Avatar
I just had this done on my truck last week. I had the original wicked wheel put in (not the WW2), new seals for the turbo housing, the EBPV deleted, and the waste gate actuator replaced. I have a 6 position chip from Tyrant (I live 5 minutes from the shop) and I was told that the tune makes the boost fooler pointless. Your tuner increases boost but still allows the waste gate and everything to work as designed. I was also informed that disconnecting / tightening / or otherwise modifying the waste gate would not gain me anything. Many people on here will tell you that your turbo won't last long over 25 psi. Also, I couldn't find any threads where someone was raving about how much faster his truck is after a boost fooler / disconnecting the waste gate / etc. It takes about 3 extra minutes to warm up in 30 degree weather, I've noticed. In my opinion, the truck is running perfectly now. The turbo spools quickly and peaks at around 23 psi. The turbo surge is gone, too. I assume you want more power so it seems like you wouldn't want to leave a restrictive device in your truck.
RexF350 is offline
post #9 of 11 Old 04-02-2013, 06:48 PM
Joel's Avatar
Quoted: 10 Post(s)
As 350 One Ton said, you can experiment with the redline and wastegate and see what you like.
I had the redline disconnected for years. I periodically hooked it back up to see if it was all in my head and sure enough I prefered it disconnected. Not to say that it was "faster" but I felt it drove better.
That turbo has since died on me though......
And FWIW, there is no adapter to use the EBPV with a van turbo, but I had one custom made just because I like the EBPV
A lot of guys delete, but a lot of guys prefer to keep it as well. Personal opinion.
The restriction is negligible at best.
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #10 of 11 Old 04-03-2013, 07:38 AM
dannanw's Avatar
Quoted: 54 Post(s)
Garage
I'd have o-rings for it, dont want to go though the effort just to cause a leak...If your speaking of the ww2 I herd they include them with it...
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
