New injectors...What kind of investment am I looking at? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 03-19-2013, 05:47 PM Thread Starter
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
What i said about, i have never been much of a performance mod person. I would probably look at about stage 2s if im doing that do i need a bigger turbo if i do that? Will my sct tunes need to be rewritten?
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #2 of 8 Old 03-19-2013, 06:49 PM
Tj Krawler's Avatar
You'll need custom tunes going to single shot injectors. IMO, if you drive sensibly, with good tuning, you could run the stock turbo. It's not an ideal setup, but it will work. It sounds like the WW G2 would do fairly well with stage 2s. A 38r would be better though.
I believe you will need an upgraded clutch to hold the added power.
Alan
2000 F-350 CC LB DRW 4x4 XLT Auto
- Intake
- Exhust
- ScanGauge
Tj Krawler is offline
post #3 of 8 Old 03-19-2013, 11:45 PM
Justin@DP-Tuner's Avatar
Quoted: 63 Post(s)
As stated, with any single shot injectors you will need the tunes adjusted.
In my opinion, I would say if you are going with stage 2's, you will need at least a 38R. You can have the injectors tuned down, but what is the point of getting stage 2 injectors if you cannot use them to their full potential?
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #4 of 8 Old 03-20-2013, 10:11 AM Thread Starter
Chapter Director
Quoted: 5 Post(s)
Ok so im looking at a tune reburn and a turbo. What advantages do stage 2s give besides more hp? Are there mpgs gains more torque etc?
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #5 of 8 Old 03-20-2013, 10:17 AM
Quoted: 63 Post(s)
You may see slightly better mileage, but the main reason for them is to create more HP/TQ.
DP-Tuner
Like us on
Justin Bochmann
post #6 of 8 Old 03-21-2013, 12:15 AM
dentexpowerstroke's Avatar
Couldn't have said it better. Also to everyone saying get a WW2... WHY???? Changing a compressor wheel won't change the fact that the turbine side and shaft is to small, all it will do is give you better airflow if the turbo can already handle that much fuel, you aren't going to get a stock turbo to start handling big injectors by changing a compressor wheel. Having a turbo that is able to handle the injectors usually means that the turbine size has to be big enough, that's where most of the issues stem from not from lack of air.
Sold 2001 f250 ccsb 4x4 400/400, dual terminators, swamps 80mm bfh, headers, bts and all the usual supporting mods. 715hp fuel only.
06 f250 ccsb king ranch
12 f250 lariat ultimate
dentexpowerstroke is offline
post #7 of 8 Old 03-21-2013, 12:47 AM
Quoted: 63 Post(s)
Not to mention, the stock turbo is limited to what boost numbers it can safely handle because of the thrust bearings.
DP-Tuner
Like us on
Justin Bochmann
post #8 of 8 Old 03-21-2013, 12:56 AM
Thank you, forgot about bearings in the post too.
Forgot to also talk about this, yes you will get more hp. But I would rather have a high hp number and low torque number. Sure, it sounds cool to say you have xxxxft/lbs, but does it sound cool to call your buddy to tow you home? Torque is what break these motors, not necessarily with that small of an injector. Really, IMO if you want to run bigger injectors talk with your tuner about pulling fuel down low to limit torque and help them motor live. The reason I say this is I ran bigger numbers on a pmr block because instead of 12-1300ft/lbs (made up number, never have cared about torque) my truck would put down a lower torque number and be safer at a certain hp level.
