10k mod w/ edge - Ford Powerstroke Diesel Forum
Old 01-18-2008, 05:42 AM
10k mod w/ edge
would there be any advantages to doing the 10k mod with my Edge set-up?
would it make the truck throw any codes?.
Old 01-18-2008, 04:39 PM
JUST DOING THE 10K MOD WILL GIVE YOU A CODE. BECAUSE YOU PCM IS SEEING THAT THE HPOP IS NOT PUTTING OUT ENOUGH OIL. SO IT MAKES IT PUT OUT MORE THAN WHAT IT WOULD IF IT WAS WORKING WITHOUT THE 10K. THE ANSWER TO THE QUESTION IS YES. I DONT KNOW WHAT IT WOULD DO IF YOU HAD THE EDGE ON WHILE YOU HAD THE 10K INSTALLED. I DO THINK THAT THE PROGRAMMER IS DOING THE SAME TO THE HPOP THAT THE 10K RESISTOR. BUT THATS JUST WHAT I THINK!
