DIY - Ford Powerstroke Diesel Forum
Old 01-16-2008, 07:50 PM
DIY
IS THERE ANY MORE DIYS THAT I CAN DO WITHOUT SPENDING ALOT OF MONEY?? SO FAR I HAVE THE TYMAR INTAKE, AND FOIL DELETE, STRIGHT PIPE. ANYTHING IS GOOD! THANKS BUDS!
Old 01-16-2008, 07:53 PM
Send a message via Yahoo to birddog
you could turn the caps lock off.
nah look around though there's stickys & writeups all over this joint.
Old 01-17-2008, 04:03 AM
zoodad, door seal mod (if your doors seem a little loose), one-time DP pcm flash (cheaper than tuner)
Old 01-17-2008, 09:45 AM
what does the DP pcm flasher involve?
Old 01-17-2008, 09:51 AM
takin out ur comp - having someone flash a new program to it, putting the comp back in basically 3 small bolts and 20 minutes from my experience
I did it last night - in the black of night with 1 buddy and it took 15 mins and on a lifted vehicle. dunno how long the flashing itself takes - but it shouldnt be all that bad
Old 01-17-2008, 10:06 AM
10k mod is decent,ccv mod,AIH delete,
Old 01-17-2008, 10:08 AM
Shaking the Bush Boss
fpr shim.....
Old 01-17-2008, 10:13 AM
10k mod and fpr shim is prob the next best ones for you
Old 01-17-2008, 01:00 PM
Can someone tell me what the foil delete and fpr shim is?
Old 01-17-2008, 01:06 PM
Ole White
Foil Delete is taking the foil off of the Driver's side Intercooler Tube and the FPR is the Fuel Pressure Regulator Shim that increases fuel pressure.
