Cool your tranny - Ford Powerstroke Diesel Forum
post #1 of 16 Old 03-12-2013, 03:01 PM Thread Starter
Cool your tranny
Delivered
Track Package
Return or Replace Items
Leave Packaging Feedback
Write a Product Review
Derale 14208 Transmission Cooling Pan for Ford E4OD, 4R100, 5R110 and5R110W
Sold by: Amazon.com LLC
Available Actions
Just wanted to share. I paid $124 for this pan. It holds an extra 7 or 8 quarts and has cooling tubes that run through the bottom on the pan. It has dropped my trans temps about 50 degrees. Excellent fit. Has a place in the pan for your sending unit, and a drain plug and comes with a gasket.
8" Skyjacker lift
2" wheel spacers
22" American Racing rims
40x15.5x22 M16's
DIY intake
Zoodad Mod
4" strait exaust
Glowshift gauges
DIY Boost Fooler
Unplugged wastegate
TS 6 position chip
dr8082 is offline
post #2 of 16 Old 03-13-2013, 03:51 AM
kystanger's Avatar
Looks interesting I may give one a try. Does it run a stock Trans filter or does it need a special filter also.
2008 f350 4x4 Stock
(SOLD)2001 f250 4x4
319,000 miles and counting.
6637 intake, 4 inch MBRP exhaust,gauges,203 degree therostat, leveling kit, transgo tugger kit, front and rear mag-hytec diff covers, more to come.
kystanger is offline
post #3 of 16 Old 03-13-2013, 04:54 AM
Quoted: 3 Post(s)
wonder how this would work in combination with the 6.0 trans cooler. I never see anything above 140 even in the florida summer.
2000 DRW CC 7.3
Exterior: 08 Exterior Clone, 22.5's
Engine Mods: GTP38R WW2, 5 inch exhaust,T500, 6637, TW tunes,DI Up pipes, 6.7 fuel pump fuel system.
Trans Mods: 6.0 trans cooler, JW Valve body,Billet triple disc converter.
Sound Mods: 7" flip out tv, 3-way speakers all around, 12" sub, 500 watt amp.
Misc:dieselsite coolant filter, max ac assist, BRV, IHD,gauges, CCV
Next up power rear window
campbellflage is offline
post #4 of 16 Old 03-13-2013, 04:56 AM
Quoted: 3 Post(s)
http://www.amazon.com/Derale-14208-Transmission-Cooling-and5R110W/dp/B004XONSX0/ref=sr_1_1?ie=UTF8&qid=1363179305&sr=8-1&keywords=Derale+14208here is the link for others
2000 DRW CC 7.3
post #5 of 16 Old 03-13-2013, 05:05 AM Thread Starter
Works with standard filter. Thanks for posting the lin;.
8" Skyjacker lift
2" wheel spacers
40x15.5x22 M16's
DIY intake
Zoodad Mod
4" strait exaust
Glowshift gauges
DIY Boost Fooler
Unplugged wastegate
TS 6 position chip
dr8082 is offline
post #6 of 16 Old 03-14-2013, 08:54 AM
Quickhorse's Avatar
Stuff from Derale is crap . . . just my .02 b/c I wasted money on one of their coolers w/thermostat. It fell apart in just a couple years. That pan looks cool but also looks very thin. Looks like a DIY tranny pan but if it works, good for you. Better than spending $400 on a cast one that serves the same function.
2008 F350 CCSB FX4 Amsoil fluids, S&B intake, 5" exhaust, Egr delete, Boss V plow, Mega Duty Title mod.
Quickhorse is offline
post #7 of 16 Old 03-14-2013, 09:04 AM
Quoted: 6 Post(s)
I use one on my Dodge 47RE and noticed a big drop in temps as well. I never had a problem with it and am happy they make one for the 4R100 as well.
2006 F250 CC/SB 6.0 Diesel
SCT 3015, Straight Piped
2002 F350 CC/SB 7.3 Diesel- SOLD
-PHP Hydra, 6637, Diamond Eye DEP-510215 Muffler Delete, GlowShift Triple Gauge Cluster.
-Plans: JW Valve Body & 6.0 Torque Converter/Cooler
bikeluver43 is offline
post #8 of 16 Old 03-14-2013, 11:27 AM
Quickhorse's Avatar
You're going to make me spend money talkin about the dang thing. Did you do it at the same time as the 6.0 cooler?? I put a BD diesel cast deep sump pan on my dodge and it helped but I think having the 6.0 cooler on my F350 combined with Amsoil tranny fluid was the biggest change in temps for my F350. My temp never goes above 130-140 unless I'm plowing and even then it's maybe a 40 increase at most so I'm not sure if I should bother.
It's like that stupid thermostat . . . I got convinced into getting that billet housing and 203 stat . . . 100 bucks i'm not sure I should've spent.
post #9 of 16 Old 03-14-2013, 12:22 PM
Quoted: 6 Post(s)
Well I only used the Derale pan on my Dodge, I never upgraded the cooler. Stock it actually ran pretty cool and didn't heat up, I added the pan for "insurance" and it did drop the temps. It never rusted out or gave me any headaches.
For my 02 F350, I will probably buy one and instead of the 6.0 cooler I actually have a Hayden (I think thats how its spelled) "The Dawg" cooler with e-fan that I'll probably run inline with the stock cooler.
post #10 of 16 Old 03-17-2013, 12:08 PM
OL' OutLaw's Avatar
here's a better pan :
PML pans FORD E4OD, 4R100 2WD & 4WD DEEP - P/N 9323
or here :
http://www.yourcovers.com/transpan_9323.php
'97 Centurion. F350 4x4 CCLB
Full Force 180cc Stage I's, D66, SRP-1.1, ARP, Banks IC, DIY E-Fuel, EBPV Del & Gut'd Ped., BD Exhaust Brake., SD IDM, HPX, BstFoolr, 4" DP - 4" exh,
6.0 Fan, 180 T-Stat, DIY Don.105006 AF, CCV Mod, BTS, W/ SD Trans Lines, Tru-Cool Max, PML Trans Pan, Bumper Mod, IssPro Gauges, Fluidampr, Mellings LPOP.....
Tuned by "The WildMan".
OL' OutLaw is offline
