Edge juice w/ attitude & boost question?
I see alot of guys running a boost fooler/regulator. I notice when I get on the throttle the service engine light comes on. I have not read the code but many people say its usually defueling due to high boost. I also rarely see over 20 lbs of boost. Will the Edge Juice disable the defueling and allow more boost or not?
Would I benefit from a boost regulator? Also since I have the attitude digital monitor would I have to add a mech boost guage with a boost regulator? |
How much boost do you see on what setting? I have a 99 with afe stage 2 and silver line 4 in and the same chip
well i got a afe stg 2 same chip and my ses light jsut flashes around 10psi but they say they juice has a fooler in it but i rarely see over 24 psi of boost so who knows ??? some help would be nice
but i can get 20psi easy im on hold with edge now ill find out if it has a fooler in it
ok jsut talked 2 edge they said there mod jsut sends the signal back 2 the pcm and tells it that its boosting fine they said yes u can buy another boost fooler and i will see some more gains in boost so i guess it will be worth a try2 get a few more psi !!!
it already has an electronic boost fooler built in.... what are your back down, boost, and EGT settings set at?
I only see about 18lbs of boost on setting 3 my turbo compressor whell is dusted bad though it has 233000 miles on it. I am getting turbo replaced next week so we will see what difference it makes. My SES light does not come on at all
back down u cant set the back down mine starts defueing a like 1100 jsut 2 be safe and u cant set a max psi u can set a warning but it cannot control the ammount of boost
i can get 25 but watch ur ses it flashses really fast on then off atleast mine dose
I have not seen mine go on and off at all.
