What is the next Mod??? - Ford Powerstroke Diesel Forum
Old 01-14-2008, 08:27 PM
I have an 02 superduty with 4" turbo back exhaust, intake and a 80hp econo flash from DP tuner. What is the next thing I should do to truck? I do not want to go balls to the walls and completly comprimise reliability. Turbo? Please let me know your thoughts and where is the best place to get it from. Thank you.
Old 01-14-2008, 08:36 PM
stack chips,,,bigger chip, water meth. ????
Old 01-14-2008, 08:37 PM
more tunes for your DP is what i would do.. and something for your trans.... valve body and TC
Old 01-14-2008, 09:05 PM
John Wood Nut Swinger
Valve body and TC. Then an ITP overboost annihilator and a turbo master wastegate controller.
That is the route I would go down.
Old 01-14-2008, 09:11 PM
I do not want to have anything to do with taking the trans out. I forgot to mention that I pull a trailer (5500 pounds total) quite a bit with the truck. The only way I want the trans pulled is if it broken and I do not want to do anything to the truck that is over kill that will kill the trans.
Old 01-14-2008, 09:18 PM
you dont have to pull the trans to do a valve body or a shift kit.... how about a secondary trans cooler to keep the temps even lower? heat is the #1 killer of a transmission...
Old 01-15-2008, 05:49 AM
With gauges you will be able to determine if you need a additional cooler. If you don't want to have to do anything with the trans, talk to Jody at DP tuner. He has some new ways of tuning that will help it last a lot longer without touching the darn trans.
