Auto to zf5 swap
I have a 2wd zf5 from a 1997 f350 bucket truck. I wanna do a manual swap in my 2000 f250 and get rid of the auto. I was curious if I could make this work or if it would be too much work. Is a zf5 from a 97 different than the one that would go In a 2000? Does anyone know if the Clutch pedal would work with my 2000 or the slave cylinder? Any input would be great!
Sent from AutoGuide.com App |
the superduty truck had a zf6 not zf5. I would think you could make everything work with a zf5, but the 2wd into a 4wd will be a pain I would think. Why are you wanting to get rid of the auto, just curious? I know a few guys that have swapped auto to manual and now they wish they had kept the auto.
Auto to zf5 swap
I drive my truck mainly on weekends and I'm always towing with it. Now my auto is about to go out I think so i have a bad taste in my mouth about them. And My last truck was a stick. I don't know if I want to pay more for the auto to be fixed as find out if I like it or do the.
About the zf5 I believe the tail shaft comes off. Would I need a transfer case from an obs to mount up or would my transfer case mount up? Sent from AutoGuide.com App |
The 2wd trans will not work unless you change the tailshaft and tailhousing which means a complete teardown. The transfercase has to be from a OBS to fit a zf5. I'm not sure what you would do for a crossmember or driveshafts though. Probally need custom made stuff. You would need a clutch peddle from a superduty truck. The hydro parts would have to be superduty too. You would be better off to buy a whole wrecked 99-03 truck to take the stick parts from if you plan to swap. You will need to cut out your trans tunnel and install a tunnel from a 6spd truck though. A 5spd will fit under a Superduty auto tunnel though.
Auto to zf5 swap
Okay that's good to know. I'd rather have the zf6 anyhow. Ill just hold off then sounds like too much work. Thanks guys
