Just installed Edge evolution and juice with attitude. Truck is a 01 250 psd. Mods are the programmers, stage 2 intake, muffler and cat delete. I'm going to the track tomorrow and was wondering what my quater mile time should be expected to be. People with the same mods are telling me 14.8 to 15.2. True??? What are some of your quatermile times??? Thanks, Mario
Depends on location - namely elevation as well as bed/cab configuration, tire size, 2 or 4wd, temperature, condtion of AUTOmatic tranny, etc...
FWIW... I ran a 15.2 with some old single file chip, and a 14.98 with DP Tuner. This is with the truck in the signature MINUS the addition of the turbo. My friend with edge w/ ext cab short bed, 4wd, sea level, cool weather, stock tires, less then 7,000 lbs ran a 15.18. |
truck is crew cab 33inch tires sea level 70 degree weather. did your friend have just the evo as far as programs go?
Lower your tire pressure a bit, practice staging while building boost, don't overheat the tranny or it'll shift like crap and your times will suffer. |
Thanks for the reply look for a new post this time tomorrow if all goes to planned. I wanna do a 4 high launch and leave at about 2000 rpm's. We will see. Thanks, Mario
i think low 15's
I agree^^^^^^
Don't worry about the RPM, worry about the boost. If you launch with at least 7psi of boost, the turbo should not lag at all. At 7psi with a stock turbo, it is considered lit. And yes, use 4 high.
I see mid 15's, at best, in your future. |
i would also say low 15's....ive ran a 15.3 on 36's w/ a hard tonneau cover on and a full size spare in the bed while launching at 20lbs of boost in 4 HI, but thats with a reg cab/long bed...just make sure that you let the truck cool down between runs so it goes a little better
Keep in mind you have more done to your truck than the OP. |
