High mileage/performance parts - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-04-2013, 04:45 AM Thread Starter
I have a 99' F350 w/ 7.3L. I've got 324, 000 miles on it and was wondering if it would hurt it if I started adding performance and aftermarket parts on it. I've many different opinions on it. Just not sure what I should do.
Richard White is offline
post #2 of 6 Old 03-04-2013, 10:07 AM
Coal Rolling = Posing
My OBS 7.3 has 310k, I've got injectors, HPOP, fuel system, etc...
The block and rods aren't any weaker than they were new, and depending on how big you go, there's no reason you can't replace the headbolts with studs, one at a time.
The question is, what's compression like?
My OBS still has excellent compression, so I'm not concerned.
Low compression could be an indicator of a worn out engine that isn't worth modding.
chvyrkr is offline
post #3 of 6 Old 03-04-2013, 02:18 PM
Quoted: 787 Post(s)
Re: High mileage/performance parts
I agree your biggest issue will be if you still have cylinder compression within spec. If so, shouldn't be an issue with basic mods.
Corey@CNCFAB is offline
post #4 of 6 Old 03-04-2013, 03:23 PM Thread Starter
Motor runs like its still new if not better. The only thing that I've done so far is Spectre cool aor intake and straight pipe.
post #5 of 6 Old 03-04-2013, 04:54 PM
99bft's Avatar
I wouldnt let the mileage hold me back on any upgrades, just get yourself a good set of gauges to monitor everything. you just have to keep in the back of your mind that it is a 324K mile engine and like anything else how you treat it is gona reflect how long it will last
99.5 F350 CREW CAB DUALLY 4X4, 4:10 (LS),ZF6 SWAPPED, RANCHO 2.5"LIFT, 305/70/16 NITTOS, RHINO LINED, B&W TURN OVER, TEKONSHA PRODIGY P3, MBRP 4" TURBO BACK, K&N CAI, PHP Hydra, Riffraff AIH DELETE, BILLET COMPRESSOR WHEEL, HPX,& "OCR", NON EBPV PEDESTAL, HIGH FLOW EXHAUST HOUSING, FOIL DELETE, ZOODAD, ISSPRO EV2 GAUGES, 6.0 TRANNY COOLER, EXTRA QUART POLISHED DIFF COVER, WARN HUBS, ARROWCRAFT SPACERS, ALPINE TOUCH SCREEN
OTHER TOYS:
65 N600 390
67 N1000 220 CUMMINS
99bft is offline
post #6 of 6 Old 03-04-2013, 09:29 PM
Winning DUHHH
Young-SC-Owner's Avatar
Quoted: 8 Post(s)
Get that off tomorrow, if you WILL be rebuilding soon. That is JUNK!
do the 6637 filter, spectre is good for a Mower, but not a forced induction anything!
Not being a prick, just letting you know before boo boos!
99.5 F-350 SRW Short Bed, Ex Cab.
6637
Wicked Wheel'd,
Southbend
Autometer - Boost, Pyro
TW 6 Pos Chip
Water/Meth Inj
Diamond Eye 4" TB
7 year Veteran with SBFD
Airframe and Powerplant Mechanic
Head Marine Technician
Dont Tread on Me
Young-SC-Owner is offline
