TS Performance install PROBLEM!!!!! - Ford Powerstroke Diesel Forum
Old 01-06-2008, 02:28 PM
Hello, Anouther newbie here, I know very little about my PSD. What I do know I have learned here. Great site!!!! Now the problem/question.
I have a 2000 PSD with pyro, boost, K&N (I will be changing to Baldwin) 4 inch downpipe with straght exhaust.
I got a 6 pos. TS Performance yesterday, stock, 50, 75, 100, 140, anti theft. I have had the computer in and out 4 times now cleaning the contacts. The truck was chipped before I got it so cleaning should not be such a problem.
With chip installed I have no "wait to start" light and it won't start.
Instructions say not clean contacts are 95% of the not starting problem, What is the other 5%.
Can I pull the chip and install the chip with batteries connected?
Thanks for any info.
Old 01-06-2008, 02:32 PM
The chip could be programmed wrong, They have to match the code on the ECM.
Old 01-06-2008, 02:41 PM
if its not a contact issue it could be a chip related issue.... was the chip made for your truck? where was it bought... i would call them up and see what they have to say...
Old 01-06-2008, 02:52 PM
Hello, Yes, the chip was made for my truck from a " mail order internet supplier". Recieved it yesterday and just getting inpatient not having it work. I probaly can get answers tomorrow, Was hoping for ideas today. Thanks for the reply.
Old 01-06-2008, 02:53 PM
Where did you buy it?
Old 01-06-2008, 03:54 PM
may sound dumb.... very dumb but did you make sure it's not in the anti-theft position of the switch. not sure what happens I have the high idle instead of anti theft. good luck.
Old 01-06-2008, 04:18 PM
Ole White
That's a possibility if not, it is probably the chip itself
Old 01-07-2008, 05:25 PM
Thanks for the replies. I wish it was set in the anti-theft, but not. I have spoke with TS tech today, tried a fix, did not work, they said return to them they would fix it for me. Still have not received a call back from vender. I will let everyone know what the happens. I see no reason to name vender till I know what the outcome is.
Old 01-07-2008, 05:37 PM
well good luck with your problem....I am just going with the tony wildman reburn, sounds promising.
Sometimes the most obvious things go unnoticed. good luck
-TJ
Old 01-07-2008, 05:46 PM
Hey Wolcott, I know very little about this stuff. So you own a TS and now you are having a reburn done. What is the avantage? How much does that cost? Where do you get that done?
