Boost question - Ford Powerstroke Diesel Forum
Old 01-05-2008, 03:09 PM
Question Boost question
I just installed gauges and TW 6 pos. Took er out for a test drive and noticed the boost gauge quit reading. Checked the T fitting where I spliced into for the gauge and it just popped off. The T fitting that I got with the gauges has a smaller diameter than the hose I spliced into so I wrapped some electrical tape around the fitting to makeup for the gap and put some small hose clamps around it. Anyway, my question is do I even need the line to be connected to the sensor thingy mounted just above the AC compressor? I would like to just run the tube from the Y pipe to the gauge instead of from the T.
Old 01-05-2008, 03:14 PM
yes it needs to be connected thats your map sensor
Old 01-05-2008, 03:21 PM
Dangit! I have an overboost anhillator on order... is that where it goes.
Old 01-05-2008, 03:25 PM
yes thats where it goes it keeps the map from seeing high boost i removed the iah and put an adapter from dfuser there to use that for boost gauge youll like the annilater
Old 01-05-2008, 03:45 PM
What is the iah?
Sorry dont have all the abbr's down yet
Old 01-05-2008, 03:55 PM
air intake heater, pretty much an uneeded thing in the intake tract that blocks air that works as an awesome spot to mount your boost guage!!
Old 01-05-2008, 04:04 PM
AIH
Which one is this...I see three connections there, one being where the map line goes in (if im looking in the right spot) and the one in the middle is a brass fitting.
Old 01-05-2008, 04:20 PM
scroll to teh bottom there is a pic of where and what it is
http://www.dieselsite.com/index.asp?...PROD&ProdID=48
Old 01-06-2008, 05:57 AM
Early 99's don't have an AIH
Luke
Old 01-06-2008, 09:02 AM
Yep. figured that one out.
