First up grades?
Ive got a 99 f350 single wheel auto. Has 122xxx miles. What should be the first upgrades to look at getting. As of now its completly stock. And I do use to pull horse trailer and machinery.
my recommendations would be gauges, exhaust, intake, 6 position chip, and a valve body.
definitely exhaust and intake first. youll get immediate results and if your pulling a lot some gauges or something like a bully dog watchdog to watch EGT and trans more precisely. if its mostly for towing a chip with tow settings or a banks trans command later down the road will probably help a lot too.
Re: First up grades?
Thanks! Im thinking about putting 4 or 5 inch mbrp turbo back exhuast. And maybe afe intake. Have any of u used the wicked wheel or batmowheel?
First up grades?
A 5" isn't worth the extra money, they use a 4" down pipe to 5" pipe back...no greater benefit than a 4" and about 100 bucks less, secondly...GAUGES!!, then after a baseline of those results, I'd recommend a good change of all fluids, then the 6637 intake, valve body, then CUSTOM tunes.
Sent from AutoGuide.com App |
First up grades?
in that order. No other posts needed after that ^^^
Intake, exhaust, gauges, and tunes. Usually people do them in that order too.
We can get you setup with any and all of those products if you are interested. Something you may want to look into is our Infinity monitor/programmer. It will work as your gauges and it will tune. It will also run diagnostic tests, datalog, read/clear DTC's, and much more. You can check it out HERE. Let me know if you have any questions. |
Damn Justin! I want one now... I need to find the money tree seeds
Well justin, I think im going to do the intake and 4 turbo back exhaust at once.
