pyro guage - Ford Powerstroke Diesel Forum
Old 12-29-2007, 09:30 PM
pyro guage
My guages were in my truck when I bought it. I'm getting ready to install new exhaust, and noticed that my pyro. guage line was in my pipe behind turbo. How much diff. in temp. readings does this make versus having it in the manifold.
Old 12-29-2007, 10:19 PM
John Wood Nut Swinger
Anywhere from 250*-450* depending on the load and the right foot.
When you replace the exhaust put the probe in the manifold.
Old 12-30-2007, 12:14 PM
whats the easiest way to put the probe in the manifold?
Old 12-30-2007, 01:04 PM
International Threat
Drill and tap it...
I also
Agree with strokin...
Old 12-30-2007, 01:10 PM
Cynic
drivers side, bottom. Drill and tap. You should have plenty of room with that lift.
Old 12-30-2007, 05:29 PM
Is there any special way I should drill the manifold, besides taking it slow? I dont want to get any shavings in there.
Old 12-30-2007, 05:39 PM
Cynic
SLow and steady. Keep the drill straight. If you do this, very few shavings will get inside the manifold. When you start the tap, make sure you are inline with the hole and make a smooth even turns. Do not press hard on the tap, let it pull itself in. Use anti seize or keep spaying wd40 on it. The cast iron is soft so it will be easy to turn.
Also, wear safety glasses.
Old 12-30-2007, 05:43 PM
Also when you are drilling and tapping if you put grease on the end of the bit the shavings will stick to the grease.
THANKS for the help guys.
Old 12-30-2007, 06:03 PM
Cynic
You are welcome.
