what do you think
just got my chip today from tony and I am wondering if he made a mistake and sent me the wrong one.I installed it and when i cranked the truck up it idle eraticaly, then I flipped to another setting and it stalled...tried to crank it back up and it wouldnt crank....checked all my connections tried again cranked up and my check engine light came on and my water in fuel light came on, switched to another setting and stalled.....I took the chip out and put everything back to gether and it runs fine....what do youlll think>?
I think you may need to clean the connection at the pcm a little bit more. Or you cleaned it far and it is not making a good connection now.
Make sure the PCM board is clean. I had a similar problem. If that doesn't do it, contact the chip programmer.
GOTCH A FREE BUMP
I just put a DP on my truck and they send a pc of scotch brite to clean the contact front and back and also recommend using polish remover to clean of the silicone. It worked great
