Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Performance Parts
  #21 (permalink)
Old 12-27-2007, 09:26 PM
scheidt27 scheidt27 is offline
not to hijack but would buying a Turbo Master Wastegate Controller be a good investment so i have a little more control, also thinking about a ATS housing
  #22 (permalink)
Old 12-27-2007, 09:32 PM
strokin_early_99 strokin_early_99 is offline
John Wood Nut Swinger
Yes on the turbo master and the ATS is a good choice for turbo upgrades. CSIPSD is running the turbo master on his new TN BB and on the two previous turbos he has run.
  #23 (permalink)
Old 12-27-2007, 09:35 PM
haha!! Got some tax money coming and thinking about the ats/Turbo Master Wastegate Controller mods for now. Dont have the money for a new turbo. Im thinking i will stop modding from there on out..........?
  #24 (permalink)
Old 12-27-2007, 09:36 PM
greenie greenie is offline
OK ,waste gate & witch line do I plug?
  #25 (permalink)
Old 12-27-2007, 09:47 PM
ABOBB ABOBB is offline
Is it even worth it???
Originally Posted by strokin_early_99 View Post
26-28psi is where the stock turbo starts go get taxed real good. When I put on the banks big head and the overboost annihilator I could push 32psi of boost. But shortly thereafter my turbo died within a couple of months. And yes, it was from overspeeding and and little heat. I drive it like I stole it all the time, even with at trailer in tow.
Ah.. but that's an turbine wheel!!
You didn't hurt yor compression wheel did you??
  #26 (permalink)
Old 12-27-2007, 09:52 PM
Not bad, just a little rubbing on the compressor housing. But isn't damage, damage. Or does turbine damage not count?
  #27 (permalink)
Old 12-27-2007, 09:59 PM
Sure it counts.. but looks to me like your exhause damage was a combination of things. High heat, and possible some over speed.
Plus.. compression wheel rubbing could have very likely happened because of the turbine wheel getting out of balance.
I guess my point in pointing out which wheel is that the guy earlier said he'd been told that a disconnected waste gate would cause compressor wheel overspeed. You major damage is on the turbine wheel, not the compressor.
  #28 (permalink)
Old 12-27-2007, 10:06 PM
That other guy that talked to his fathers friends buddy that has a cousin that was married to a gal and her father owned a shop that said it was not a good idea need to talk to a person who knows powerstrokes. Then he should post up.
Now for my pic, All I was saying to someone, before the pic, is at 30-32psi all the time and 28psi with a trailer will kill a stock turbo if you run it past the efficiency map like an idiot. And that is the first turbo I killed, then another reman died in another 4 months of abuse. Then I got a D66 and all was good.
  #29 (permalink)
Old 12-27-2007, 10:08 PM
DJM DJM is offline
I have the Banks wastegate already but 25lbs is the most I have seen. So would plugging it off even help? Or is 25lbs a good number.
  #30 (permalink)
Old 12-27-2007, 10:10 PM
I'm agreeing with you man.. I really am.
Was basically just pointing out that you killed the opposite side of the turbo from what the so-called expert told the other guy he would hurt!!!
I've intentionally stuck with my Hypertech for as long as I have, because I knew that with hotter tunes.. I'd be just like you. I'd flog it til something broke. Now.. things are starting to fall into place.. and I'm working on a plan to build things up.
