CAN I KEEP THE EDGE W/AT. IN ?
thanks, puffin |
Delete the edge cause the psds dont respond too well when you stack chips.
Turn the edge to 0 or off or whatever you need to do to only use the gauges. Then put in the chip of choice.
thats why i was askin is cause i wanted to use the attidude as a monitor what do you yall think of the wildman chips ? they seem like everybody wants one or is talkin bout them . how is an install on 1 of them ?
Install is a breaze. In the 7.3 tech section under modifications there is a video. It takes me less than 15minutes to install a chip in a virgin PCM and under 5 minutes to swap out the chip in my truck.
just watched the vid im pretty sur e if anyone can hook up the edge that they can hook up those chips thats alot easier the i thought ! thanks yall
what tunes you recomend with my upgrades that i have in the sig.?
econo daily light tow heavy tow race extreme let me know if you have any questions about them: Stealth Automotive. Tony Wildman Chip -Raul |
i realy want to pull out a little more perfomance out of the 7.3 then the edge does but i also want to keep it running as longs as i can i looked at the different tunes earlier on your site and i was thinkin of doin a 4 pos. with econ,street,smoke,and extreme or stock what are the ratings those different tunes ?
