OK so i tried last week, and didnt gert any info. Ill try again.....anyone have any info on this. several other guys wanted to know as well......It's fairly cheap....but does it work other than the external fuel filter?? Thanks for any help
ITP 7.3L Fuel Tank / Pre-Pump Kit Last edited by ksttac; 12-26-2007 at 02:25 AM. Reason: more info |
i am kind of slow,are you asking if this is just an external fuel filter or are you asking if it raises performance?i am curious also
I suggest you e mail Dennis at ITP, he will answer all of your questions.... this kit is nice and does as it says.....
If you are asking if it works as it says, it does. It quited down the injectors at idle and my fuel pressure did not drop as much at WOT. Before I did the mod the fuel pressure would idle at 68psi and drop to 50psi, after the intake mods it would only drop to 56psi. So I say it works. I am currently using the same intank mods on my high flow system and it seems to work just fine. Keep Strokin' |
strokin 99 answered my question...i just wanted to know if it does what it sais, quiets injectors and hopefully prolongs them. the fuel filter is just a bonus.....how hard was the install?
I did the same mods to my truck plus I cut off the filler and vent tubes while I was in there. Now she runs a lot quieter and holds about 7 gallons more fuel and does not splash back on me anymore but best of all the filter means I am more protected from a bad load of fuel. I did all this for $30 worth of parts from TSC and it took about 4 hours. Here are the pics I took. Shutterfly | View Shared Pictures
