rebuilding turbo waht set up? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 12-25-2007, 06:07 PM Thread Starter
well i want to rebuild the turbo bec we are pulling the motor because of the busted A** oil pan. so i figured ide get the kit from Ron turbo service. the major rebuild kit with banks wheel for 165 bucks. good deal. or get somthing else..
andrewlawnrangr is offline
post #2 of 6 Old 12-25-2007, 10:14 PM
Deputydog's Avatar
Its a good deal if you plan to stay stock or small upgrades like a chip.. Ron's does good work too..
2002 F350 Crewcab Lariat 4X4 SRW
626 HP, soon to be 750+ HP on fuel only
Deputydog is offline
post #3 of 6 Old 12-25-2007, 10:25 PM
what year truck??? what other mods???
2002 F350 XLT 4X4 7.3L Auto, Reg Cab, 3.5" lift, 35" BFG ATs, 6637 Filter, 4" Exhaust with Cool Duals, TN Turbo and high flow outlet, Fass fuel pump, regulated return with fuel bowl delete, 6.0L IC, SS HPX, DP tuner 40T 80E 120R, Gauges, 2005 Headlights and Grill
Next: Hybrids and new tunes
Mr. Bob is offline
post #4 of 6 Old 12-26-2007, 12:28 PM Thread Starter
2002 7.3 4" mbrp exhaust. intake afe stage 2 dry. zoodad mod soon a adjustable chip.. 4 settings. guages.
post #5 of 6 Old 12-26-2007, 09:27 PM
sirnunya's Avatar
custom tunes or what? if you just getting a regular chip just rebuild the stocker. if you get custom tunes you will probably want injectors later, than another turbo, etc etc. you'll find out.
sirnunya is offline
post #6 of 6 Old 12-27-2007, 07:51 PM
powerstrokindad's Avatar
i got the rebuild kit from ron a few months ago...easy install and pleased with the results...Rod
2000 F350 Extend Cab ZF6 DRW 2WD
*Edge Juice*FBD 4" Exhaust dumped in front of rear axle*6637 intake*ZooDad Mod*CCV Mod*BD X-Monitor*DIY Map Fooler*Rebuilt Turbo*Banks Big Wheel*Tighted WG Actuator*EBPV Delete*Cleared Light Covers*Foil delete
Towin a 42' Franklin 5er with triple axle's and a 5th wheel to gooseneck adapter, grossin about 16000 lbs.
powerstrokindad is offline
