Fpr mod and ****ty gas mileage??
i did the fuel pressure regulator mod and my gas mileage went from like 15.0 to like 10.5. i didnt change anything but the FPR mod and it went down like crazy.
thinking about taking the shim out. has anybody else experienced this or am i the odd ball??? |
is it maybe winter blend fuel that usually drops a few mpg when u start running that!
i was getting 15 with the additives in it and i had a half tank did the mod and like the next time i took my truck out it just like went down. i mean my truck seems to idle better, better throttle response and stuff but dang my mrg's drooped by like 3 to 4
Never herd of that happening in the last 5 years I have been recommending shimming the FPR.
Do you have any fuel leaks from the higher pressure? When I did mine in 2000, I found two leaks from the added pressure. |
i think my drain valve might be leaking but im not sure. where did u find leaks at if u can remember???
I found two causes of my issue with poor fuel mileage, 1. my foot gets to heavy when the light turns green. 2. fuel drain valve leaking. I fixed the leaking drain valve, cant seem to fix the 1st problem though!!!
SO it's ok to do this mod with a chip right? I have a 100hp chip wich is probably actually 75hp just don't want to be breaking anything else.
Merry Christmas |
Well if your talking about getting the fuel as far as how much the fuel pump can handle I have a Fass pump just havn't got around to installing it yet or were you talking more in the case of the injectors? And yea I have already found that the tranny is the weak link I pretty much toasted it when I got it towed home I drained the fluid and it was dark red and very shiny. Thats been upgrade though. Merry Christmas to you too.
can you tell a differance with the mod power wise?
