Help with my combo. - Ford Powerstroke Diesel Forum
Old 12-23-2007, 01:19 PM
Help with my combo.
Hey all! It's my 1st time here. Great forum!! I would like some of you guys to critique my combo & let me know what you think. I have a late 99 f-250 w/ a 7.3 & automatic trans, 4wd, crew cab, flat bed. It's my work truck/welding rig. I have a 1400lb lincoln welder on the back & about 1000lbs of additional tools on it. I run 33" tires with stock gears. Anyway, I installed a banks 6-gun, mbrp 4" turbo back exhaust, banks wastegate actuator, cold air intake kit & a banks transcommand. I run full synthetic oil in the engine. Anyway. under part throttle it runs ok & pulls pretty decent on any power level from about 3 & up. But under full throttle, it doesn't seem to pull any harder & possibly less than part throttle. I took it to a friends tranny shop & had him test drive it & he thought the trans felt fine. I thought it was slipping. I just recently upgraded my welder which added 700lbs & now under hard acceleration, I feel a shutter coming from somewhere. Is this a converter/trans problem? Also, with the above listed mods, I can't get more than 19lbs of boost no matter what. Is this normal? This is my first diesel & I need some education on how they perform. Thanks for your help! Bill.
Old 12-23-2007, 01:22 PM
Welcome to the site, remember this of all things, turbos start to kick in about 2200 RPMS and up, the shudder could be a u-joint maybe or something in the tranny about to out...
have you tried it without the trans command?
Old 12-23-2007, 01:25 PM
with the above mods you should see mid 20's for boost... you could possibly have a boost leak somewhere... if it was me i would ditch the banks 6 gun and get yourself a custom tuned chip.. .i can get you a tony wildman chip with 2 tow settings(heavy and light tow) with that amount of weight your always carrying i would suggest you have both of those tunes.... let me know if you have any questions.... oh and welcome to the Org
Old 12-24-2007, 12:58 AM
Thanks guys! Stroker, I have not tried it without the Transcommand. Now that you mention it, is there any way to get rid of the "off idle lag" for lack of better words? Raul, I would like to keep the six gun for the porpose of the boost & egt readings it supplies. But I am open to stacking another chip on top of it if that works. what kind of gains can be expected from Tony's chip over the banks? Thanks, Bill.
Old 12-24-2007, 06:47 AM
John Wood Nut Swinger
The banks is good for a max of 65hp. The TW chip can make over 100hp. If you go that route turn the banks down to 0 and run the chip on whatever tune you want. Stacking the 6gun and the TW chip will not gain much. The most I have seen the banks help in a stocking combo was 9hp.
If you go with a TW chip ask about tuning for a H2E turbo to aid in spool up. Or get a DP tuner and get his H2E tuning. I have DP tuner with tunes for an H2E turbo and my turbo(bigger and heavier than stock) spools great. I tow quite a bit with it and lag is all but gone with the tuning I have. At 1600 rpm my turbo lights up real nice.
Old 12-24-2007, 08:55 AM
Thanks for the suggestions guys! Can you guys spell out for me in dummy terms some of the abbreviations? I read some of the other posts here & by the time I was done, I had learned nothing more than before I read them. Lol! What's an h2e turbo? Also, the Banks wastgate actuator is adjustable right? Could it be that I adjusted it incorrecctly & that's where the low boost is coming from? Just trying to learn as much as I can from you guys. Thanks, Bill.
Old 12-24-2007, 09:06 AM
KVFD
welcome to the .org bud!!! heres a bump up for ya!
