Egt probe; post turbo or per torbo? - Ford Powerstroke Diesel Forum
post #1 of 21 Old 02-20-2013, 04:44 PM Thread Starter
Wannabitawerm's Avatar
Was told today the manifold was better. If so, which side and where? Also told downpipe is inaccurate.
Sent from AutoGuide.com App
Wannabitawerm is offline
post #2 of 21 Old 02-20-2013, 05:33 PM
Tj Krawler's Avatar
Exhaust manifold is the only accurate place. Most put it just before the up pipe. Driver side manifold is easier to access.
Temps in the down pipe vary too much to be used reliably. One day they may be 200* lower than manifold temps, the next day could be 400*+ lower.
Alan
2000 F-350 CC LB DRW 4x4 XLT Auto
- Intake
- Exhust
- ScanGauge
Tj Krawler is offline
post #3 of 21 Old 02-20-2013, 08:23 PM
Premium Starfish Member
AzPatMan's Avatar
Quoted: 31 Post(s)
I agree with Tj,
I also read somewhere that the drivers side is the manifold you should tap into.
For some reason - this side is a bit hotter than the passenger side.
Why I don't know - but there was a another thread where a couple people verified that
by running seperate probes on each manifold.
So they say just use the Drivers side to get your 'highest' temp readings.
2003 EX, 7.3L 4inch Lift, Nitto Trail Grappler's, KMC XD Spy's
220k Miles, Currently 605tq, 312hp
AzPatMan is offline
post #4 of 21 Old 02-20-2013, 08:25 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 19 Post(s)
Pre turbo I run dual pyros and mine is between 50-100 hotter on the drivers side.
dhanna6powerstroke is offline
post #5 of 21 Old 02-20-2013, 10:41 PM Thread Starter
That makes it even easier. Thank you for the replys.
post #6 of 21 Old 02-21-2013, 08:30 PM
hansel's Avatar
Quoted: 94 Post(s)
You want the temp reading before the turbo, my brother explained that the temp is lower because the pressure is lower after the turbo. Pressure (heat) is higher before the turbo because pressure is what spins the turbo, and the turbo pressure (heat) is lower when it discharges that heat, thats why the best place to read the temp (EGT) is before it goes in the turbo.
Heat=pressure
Higher pressure into the turbo, lower pressure coming out.
2001 7.3L CCSRW 4X4
Airiad Intake 4" Flo-Pro Exhaust
ISSPRO EGT/Transmission
PHP Hydra
2015 Heartland Prowler
hansel is offline
post #7 of 21 Old 02-23-2013, 01:59 AM
AUSPowerstroke's Avatar
This is something that has got me thinking swell, over here on all out diesel 4x4s its unheard of putting a pyro in the manifold, they all go in the dump pipe, (my old nissan patrol had it in the dump) but everyone on here says manifold, I went to a exhaust shop and got told to put it in the dump as the manifold is a big lump of steel and can possibly heat soak the sensor and being a big lump of steel will take longer to heat up and cool down, havent fitted it yet butthink I'll just put it in the manifold as that what everyone reads on off here so might make diagnosis a bit easier if I ever have problems and ask for help here
2003 F250 7.3l (RHD), auto, 4"lift, 315/75R16's, arb steel winch bar, 12,000lb winch, 30" LEDlightbar and 2x lightforce 240 spotlights, Snorkel, edge cts attitude tuner, 5"stright through exhaust, Custom made rock sliders, Front and Rear ARB air lockers, still more on the list to be done
AUSPowerstroke is offline
post #8 of 21 Old 02-23-2013, 01:24 PM
Winning DUHHH
Young-SC-Owner's Avatar
Quoted: 8 Post(s)
The probe is sticking in the exhaust stream, constantly varying with the amount of fuel being delivered, listen to us, not them!!!
99.5 F-350 SRW Short Bed, Ex Cab.
6637
Wicked Wheel'd,
Southbend
Autometer - Boost, Pyro
TW 6 Pos Chip
Water/Meth Inj
Diamond Eye 4" TB
7 year Veteran with SBFD
Airframe and Powerplant Mechanic
Head Marine Technician
Dont Tread on Me
Young-SC-Owner is offline
post #9 of 21 Old 02-25-2013, 12:15 PM
Also the driver side manifold offers the cleanest wiring (out of sight) if looks matter.
White POWERSTROKE is offline
post #10 of 21 Old 02-25-2013, 08:44 PM
hansel's Avatar
Quoted: 94 Post(s)
Here is another thing too think about, I was into drag racing Mustang's a few years back and turbocharging was getting big, those guys have a EGT at every cylinder, they use those temps too help tune the motor. They don't use the temp reading after it passes the turbo. I think the ideal spot is where the "Y" pipes feed into the turbo but what a pain in the butt that spot is unless you want too take the turbo out.
2001 7.3L CCSRW 4X4
PHP Hydra
hansel is offline
