Banks Aftermarket Gauge Replacment Help
I just bought a 2001 Ford Excursion with the 7.3 and it clearly has a Banks Kit of some sort installed on it. It seems to have exhaust, intercooler, and the big head valve. Not sure if the turbo housing and impeller has been upgraded or not. There is a Banks Dynagauge EGT gauge and a Banks Dynagauge Boost gauge on the A-pilar. The boost gauge works but the EGT gauge seems to be stuck in the 250 to 350 range. It only moved when you tap the gauge. The gauges are rather ugly and I would like to replace them. Are there any other gauges that will work with the Banks gauge sender units? I would rather not install new senders and run new wires. Thanks in advance for any help!
