new 35's - Ford Powerstroke Diesel Forum
post #1 of 11 Old 12-19-2007, 06:34 PM Thread Starter
zataca's Avatar
new 35's
Hey my tires are gone time for new 35's. They are 35/12.50/16.5 BFG MUD with 57k on them (thank you BFG) but i'm having a hard time finding them in 16.5". Not where I bought them Les Schwab not at Americas Tire Co. Any help on a good tire that lasts.
________________________________
2000 F-350 Crewcab Lariat 4wd Black
4" lift 35" BFG Mud TA'S 3 Stage Chip
zataca is offline
post #2 of 11 Old 12-19-2007, 06:37 PM
M4 in my tool box
Pullinpower7.3's Avatar
I had trouble finding 16.5 also. I wasn's looking for 35s but i had luck with ground hawg radials. They ran about 47,000 under a 97 f-350. They might have them in 35 but I think they will be wide ones (14.50). Good luck.
2001 F-250 X-Cab 4X4, Edge EVO, DIY Tymar, Map Fooler, FPR Shimmed, 4" exhaust into 7" GR Bullhauler stacks, 3.5" fabtech lift,35x12.50 procomps, 18" DEJ cannon wheels, Custom built RobTrans, HD U-joints, Trip A-pillar Guages, 2 12" rockford subs 1500watt rockford amp and Eclipse head unit, More to come!
Proud USAF Vehicle Maintainer, With out US, YOU walk!
Pullinpower7.3 is offline
post #3 of 11 Old 12-19-2007, 06:38 PM
John Wood Nut Swinger
strokin_early_99's Avatar
Try a small local shop. My brother runs 16.5's and he only found one place to get them, a local goodyear tire shop.
(Born on 11-20-98) F350 CC LWB 4X4
north of 480hp and south of 13.7sec
Bored with current setup
Family of 5 saved by Grace.....
Sponsored by Left Coast Diesel in Concord, Ca
Anything BUT Conservative Performance
strokin_early_99 is offline
post #4 of 11 Old 12-19-2007, 06:39 PM
willypscustoms's Avatar
they are all pretty much discontinued. best luck is sst interco tire they pretty much are the only ones still making 16.5 tires i have a set of 37 1250 16.5 Goodyear mt
IF CAPS ARE ON IM AT WORK I CANT TAKE THEM OFF
willypscustom cold air intake
4" exhaust straight piped
banks 6 gun
itp regulated return
dp tuner
9" lift 37" tires
agr hydro. assist steering
greddy turbo timer and greddy gauges
wicked wheel
and some other small mods
willypscustoms is offline
post #5 of 11 Old 12-19-2007, 06:42 PM
CSIPSD's Avatar
Sounds like time to step up to a 17" or 18" wheel and go for the best tire on the market... TOYO MT'S!!!
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #6 of 11 Old 12-19-2007, 06:43 PM
M4 in my tool box
you can find 37 12.50 16.5 goodyear MT HMWWV (hummer) military tires at surplus stores and on the internet for days. 35s are very rare. Might mb time to upgrade to a different size wheel with more tire options.
post #7 of 11 Old 12-19-2007, 06:45 PM
wd13's Avatar
I run the Parnelli Jones tires. 36x14.5-16.5 A little wider than what you've got but they've lasted well so far. They are pricey though. Also as posted above, the Denman Ground Hawg's seem to last.
wd13 is offline
post #8 of 11 Old 12-19-2007, 06:48 PM
for the price of pjs you could have 17s with new tires
banks 6 gun
dp tuner
9" lift 37" tires
wicked wheel
post #9 of 11 Old 12-19-2007, 06:52 PM Thread Starter
zataca's Avatar
How do the toyo's wear. My buddy has 35" toyo's on his expedition and it's time for new at 31k
zataca is offline
post #10 of 11 Old 12-19-2007, 06:56 PM
CSIPSD's Avatar
70k on the first set... 50k on this set so far...
Joe
CSIPSD is offline
