dp tuner question - Ford Powerstroke Diesel Forum
Old 12-17-2007, 07:40 PM
dp tuner question
ok i have a dp tuner in my truck, runs great with it. question i have is with the chip install the stock radio in my truck is horrible i get all kinds of interference. i know its caused by the chip because i tried removing the chip and the radio stations are clear with it out. just wanted to see if anyone else noticed this with there dp tuner? is it normal or is something wrong with mine?
Old 12-17-2007, 08:13 PM
John Wood Nut Swinger
Play with the routing of the cable. I had to route mine around the bottom of the lower removable panel and then up to my chip. That made the interference go away.
Old 12-18-2007, 02:35 AM
Powerstroke Junkie
How long have you had it? Do you have the new shielded cable? Call Jody if you are not sure.
Old 12-18-2007, 03:35 AM
Send a message via MSN to JoeyCleland
yeah its definately the chip. Try This.
turn the key to the ON position and turn your radio on. Then try different cable routes on your DP tuner. Mine interfered terribly on the left side of the steering wheel, but when I moved it to the right it went away. Just takes some trial and error.
Joey
Old 12-18-2007, 12:02 PM
i've only had it for a month or so, got it from itp diesel. not sure if it is the newer cable or not. what the difference on the two? i have it ran up along the door molding up to my pilliar. i have the gauge mount for the switch. i can't really mount it two many other ways.
Old 12-18-2007, 05:40 PM
If the cable is round it is the new one. If it is flat, it is the old one.
If you have the gauge mount and it interferes, call Jody. He can help.
