Got hosed while doing the FPR mod
i was doing the FPR mod and when i went to check the pressure i didnt tighten the clamp on the gauge right and got soaked with diesel. fun fun!!!!!!
also for those of u that did the mod already how bid was ur shim???? |
1.77cal BB bumped mine to 69psi.
Tell your girl that you are wearing a new Manly cologne called Rudolf(for Rudolph diesel) ....LOL....It sounds good on the surface but I don't even think my wife would go for that and she is a diesel enthusiast. |
Heck you got lucky!! I broke the whole thing while tightening down the tee to the new pressure gauge. $300 bucks later i'm rollin again!!
Ouch! $300 Man, you need to post stuff like that on here. I have a fuel bowl sitting on the bench lonly. It missing being in a truck to keep it company. We could have struck a deal. |
That's cool but unfortunately my truck was in Maryland and i live in Pa. and didn't have the luxury of waiting!! Trust me if i had the time for the truck to sit i would've posted it up!! That's just the way it goes i guess.
i just took a Bolt and grinded it down to were the head was the height of a nickel which is .060 and the thread part fit inside the spring i didn't get a chance to get a Good reading do to the fact i had to clean the fuel off the floor.
how are u guys hooking up your gauges??? i just put clamps on the drain valve from the bowl to the copper tube then hooked a tube to the bottom of the drain valve then hooked a gauge to the bottom of tube and opened the drain valve then i turn the ignition on and looked at the gauge and all i saw was diesel shooting at me. does that sound correct? well what were the heights of the shims u guys used?????? and what r the benefits of this mod??? Last edited by teamcasslake; 12-17-2007 at 05:40 PM. |
That should work.
When I did my gauge that wasy I got more fuel all over the place than any other time in my life. The darn hose kept sliding off he smooth nipple on the valve. I ended up taking it off and grooving the nipple to keep it from sliding off. Then I got the alternator mounted fuel pressure gauge from DI and that fixed that problem.
how does the alternator mounted fuel pressure gauge hook up????
i checked the pressure today and after i checked it i moved the truck and it was spitting fuel out the drain tube with the valve closed. did i blow the O-rings out or something???? and what are the benefits of raising the pressure?? |
