This thing now has insane power but i have a few questions. When you punch it in the 80 and 120 well in all the settings it runs through first gear nice but then at the end it seems like the truck maybe defuels or the tranny is confused and hesitstes to shift into second and seems to bog down for a second then shifts and you go again. It also seems to maybe get confused between 2nd and third as well, it will downshift fine then upshift real quick and then back down, like its confused or something Jody has the tranny tuned so i dont need a valvebody. Do i need a Valve body? And then the OD light started flashing on the shifter as well. Whats going on here. Tranny slipping? Does my shifting need to be tweaked a little or is the tranny just too weak. it has 62000 unmolested miles. Also it shifts fine when you ease it down to the floor, it only happens when you puinch it. Any input would be great
If the OD light flashes it is a trans problem, not an engine problem.
I went to JW's shop and they installed everything. I watched him modify brand new parts, take new parts apart and change internals and throw stuff away. I probably drove him nuts with all the questions but he said it was OK, it is normal. He has towque convertors there that were cut apart so I could see the intrenals. We even cut my TC apart on the lathe and it was burnt up inside.
Ok guys need some input/advice here on what to do tomorrow. Right now the chip is tuned so that there was no need for a valve body, should i have jody retune it for a valve body and see if that helps teh shifting or no. Also I think i will bring it in to a place up here called Boyer Trucks, they sell all lines of ford trucks, light, medium, and heavy and service them all. I trust them more than the dealer. Or should i have a code ran before i even talk to jody? Thanks in advance
It would be the one in minneapolis off of broadway. according to the website that is the only one that services the light duty trucks. I hate to repeat my self but just got done drivin this thing again, it only acts funny when you punch it and hold it but not when you ease into it. Also when i was flippn through the tunes teh SES light came on when i put it in the stock mode. Im just gonna have to talk to jody tomorrow.
Also which setting did the SES light come on? 80? 120? 140? It's likely that it's demanding too much ICP and tripping the HPOP code. Nothing to worry about if that's the case. At the very least you should try and find an auto parts store like Autozone. They have code readers that you can use for free. Then come back here and post your findings.
Some times the tuning takes a couple of trips back and forth to get it right for your truck. I know mine did. Talk to Jody and let us know what he says.
on my most recent drive the SES light did come on but only when i flipped it back into the stock mode, then when i flipped it back to the custom tunes the light went back off. any idea?? Maybe i will run back to autozone
just got back from autozone, no codes found? somethins funny here, anywhoski i'll quit buggn everyone until i talk wit jody tomorrow, thanks all for the help! much appreciated!
Got the codes pulled today, the tranny was just a 1-2 shift error, there were a few other unrelated ones as well. Anyways the tranny is obviously not up to the task of the new found power, slips under WOT in the 120/140 settings, will a valve body help with this, im guessing not? Would it be a waste of money to put one in if im gonna be getting a new tranny next summer, or I may just have to take it easy in the 80 econo until i have enough money for a john wood or bts i guess! Anyone have any advice?
Pull the chip put and drive it like that for a day and then see if there are any codes. If there are not any codes, call Jody. If there are codes then your tranny is shot.
This is the next round of testing. woohoo.
i know my OD light flashd and about 2 weeks later the tranny was shot i was shiftin outta gears at redline for about 15 miles passing up cops with the truck roarin i thought forsure i was going to get a ticket
yea this afternoon when driving it again i tripped another code tryin things , the od light flashed again. So theres another code. Im not sure if the tranny shop i went to is gonna like me coming back to use their scanner for free a few more times. I took it to a AAMCO place cuz i found a free diagnostic coupon and they had a snap on scanner they hooked up for free, the truck place i called wanted 206, f-that.
The light turns off after you shut the truck off, it doesnt stay on all the time. dont know if that changes anything
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
