EGT's with stock truck with tunes - Ford Powerstroke Diesel Forum
post #1 of 14 Old 02-01-2013, 06:51 PM Thread Starter
Should I be concerned about EGTs on a stock truck other than a PHP Phoenix that I generally run 65 Hp dd or 80 hp dd?
edeano86 is offline
post #2 of 14 Old 02-01-2013, 07:38 PM
7.3Lariat's Avatar
Simple answer yes.
______________________________________________
Mike
SOLD
Mods: BD-X monitor, 6637, BTS, GT38R, Snow MPGMax, International up-pipes, Hi-Flow Outlet, 5" Diamondeye, HPx, FRx, Gearhead tunes, Tru-Cool tranny cooler, Remote Start
376HP 791ft-lbs on 10.15.11
7.3Lariat is offline
post #3 of 14 Old 02-02-2013, 04:07 AM Thread Starter
Ok, of course I'm concerned about it. Does anyone have some numbers from monitored EGT of stock trucks and tuned trucks? Would it help tremendously if I deleted the muffler? I'm trying to keep my truck as pristine as possible. It's an 01 ECSB with 80k
edeano86 is offline
post #4 of 14 Old 02-02-2013, 05:21 AM
I ran canned SCT tunes on my truck with stock exhaust. Never saw EGT's over 950-1000 with getting on it fairly hard. I was mostly driving like grandpa though. (Trying to go for high mpg's)
I did however take the tunes off and go back to stock.
Pipewrench is offline
post #5 of 14 Old 02-02-2013, 06:15 AM
7.3Lariat's Avatar
Why not just add a gauge?
Mike
SOLD
post #6 of 14 Old 02-02-2013, 07:20 AM
03machstock's Avatar
My truck performance wise is stock, well a 6637, but that is more for filtering than it is performance. Anyway, cruising i usually see 400-450 ish on flat ground, and 5-800 on hills pulling in 6th. Highest i ever saw was 9-950 getting on it good up a hill. I have not had my guages for very long though so might see some more severe temps on really big hills. Hope this helps.
e99 F-250 Regular cab lariat 4x4 manual transfer case, 6 speed 7.3
Warn Premium Hubs
Isspro ev2 Pyro and Boost
6637
MBRP 4" with muffler
Rigid D2's
03machstock is offline
post #7 of 14 Old 02-02-2013, 07:32 AM Thread Starter
Yeah that does. I appreciate it.
edeano86 is offline
post #8 of 14 Old 02-02-2013, 08:55 AM
To add to that as well, my truck has a cat with the stock system so im sure that increases egt's vs some 7.3's that came without them.
Warn Premium Hubs
6637
Rigid D2's
post #9 of 14 Old 02-02-2013, 08:58 AM Thread Starter
Yeah. Mine doesn't have a cat
edeano86 is offline
post #10 of 14 Old 02-02-2013, 01:54 PM
88kevina's Avatar
Then you would know for sure
2000 F-250 4x4 ext.cab 6-speed
South Bend Clutch, Pyro & Boost, 6637, 5" Exhaust, CCV, FRX, 203* T-Stat, Coolant Filter, Bypass Oil Filter, 5/8th Fuel Pickup, Pre-Pump Filter, Melling Lpop, Stealth Srp 1.1, Swamps IDM, S366, AND Tunes from Jody(80/100/120)
"Speak softly, but carry a big stick" T.Roosevelt
KCCO
88kevina is offline
