When is 5/8 fuel tank pick up nessasary? - Ford Powerstroke Diesel Forum
post #1 of 16 Old 01-31-2013, 04:43 PM Thread Starter
88kevina's Avatar
Starting to prep my fuel system to handle bigger injectors by installing Strictly diesels fuel tank/pre-pump kit. I noticed they offer a larger fuel tank pick up but have this noted in the description. "NOTE: This product is not intended for use with the stock fuel pump. If you will be running the stock fuel pump and are looking for pre-pump fuel system modifications, check out the PRE-PUMP /TANK KIT.". Why isn't it recommended to run with the stock pump? at what point is a 5/8 pickup needed? And could i use it for a while with my stock pump? I will eventualy add in a second pump or fuel lab pump or fass system or air dog setup and I would like to only have to do any in tank work once.
2000 F-250 4x4 ext.cab 6-speed
South Bend Clutch, Pyro & Boost, 6637, 5" Exhaust, CCV, FRX, 203* T-Stat, Coolant Filter, Bypass Oil Filter, 5/8th Fuel Pickup, Pre-Pump Filter, Melling Lpop, Stealth Srp 1.1, Swamps IDM, S366, AND Tunes from Jody(80/100/120)
"Speak softly, but carry a big stick" T.Roosevelt
KCCO
88kevina is offline
post #2 of 16 Old 01-31-2013, 04:44 PM
Njstroker91's Avatar
Have you considered a sump kit rather then draw straw style. Just another option for you to consider
Sent from AutoGuide.com App
2006 f350 eclb 6 speed, powermax, billet compressor wheel, valair dual disk, 4in to 6in cat stack, afe magnum force stage 2, airdog 150, xdp sump, zoodad mod, sinister coolant filter, gauges egt oil temp and fuel pressure, cfm carbon fiber and metal cold side tub, blue spring, bpd ficm, moto metal 959 18x9 wrapped with cooper at3, custom shift knob from lilpooh, Polk audio all the way around, dashboss for monitoring
Njstroker91 is offline
post #3 of 16 Old 01-31-2013, 04:55 PM
jesilvas's Avatar
Quoted: 3 Post(s)
If you do that pickup, you get rid of the stock "prefilter." Same with a sump.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #4 of 16 Old 01-31-2013, 05:15 PM Thread Starter
88kevina's Avatar
Have not considered a sump kit, I can only think of advantages. Any disadvantages to a sump? I am adding in a pre pump filter an eventually a post pump filter so the in tank pre filter wont be needed
KCCO
88kevina is offline
post #5 of 16 Old 01-31-2013, 06:11 PM
jesilvas's Avatar
Quoted: 3 Post(s)
Sump requires no tank drop, and pump doesn't have to pull fuel up the tube.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #6 of 16 Old 01-31-2013, 06:37 PM
X2^^^ gravity fed compared to pulling against gravity. You could also then change out to whatever barb size to match the hose you wanna run to suit your needs. Also with the draw straw if you don't cut it the correct length you will get a 1/4 tank issue where you suck air before the tank is empty.
post #7 of 16 Old 01-31-2013, 06:48 PM Thread Starter
88kevina's Avatar
Does anyone make a sump kit?
KCCO
88kevina is offline
post #8 of 16 Old 01-31-2013, 06:51 PM
I'm sure one of the site sponsors would have a sump kit. I got mine off xdp but any the major aftermarket company's have them. I have heard good things about the Hellman sump but to me there all the same.
post #9 of 16 Old 01-31-2013, 06:55 PM
I got a good deal on eBay used even can look there.
post #10 of 16 Old 01-31-2013, 07:03 PM Thread Starter
88kevina's Avatar
Thanks for the info! So when does a sump really become necessary?
KCCO
88kevina is offline
