6637 clearance question - Ford Powerstroke Diesel Forum
Old 01-27-2013, 03:11 PM
I did the 6637 mod on my truck but did not remove the plastic battery housing.
it appears the top of the filter is making contact with the underside of the hood when the hood is closed. Do you think this is cutting off my effective surface area of the filter? Thanks
Old 01-27-2013, 03:38 PM
Behavior Modificationist
Nope. Its a tight fit for everybody but still very effective.
Old 01-27-2013, 03:43 PM
Ok, I was considering cutting the plastic up under the filter off (where stock airbox was) to make more room but I guess it is unnecessary. Thanks
Old 01-27-2013, 04:13 PM
Mine is in contact with the hood as well
Old 01-27-2013, 04:15 PM
I did cut out the bottom of the old air box.
Old 01-27-2013, 06:16 PM
Same here. I cut out the bottom of the box.
Old 01-28-2013, 02:15 PM
I cut out the bottom also
John
Sent from my Autoguide iPad app
Old 01-28-2013, 04:30 PM
Those guys that cut it out...did you just take everything off, and then use a sawzall or zizwheel and cut it flush?
Old 01-28-2013, 04:38 PM
Just left it in there and cut it out.
Old 01-28-2013, 07:23 PM
E99=pain in the arse.... Wouldn't recommend it.
