Fuel/ Air Dog II mods
Im going to do the AD II in the next week or two and have been looking at all the parts included in the kit and decided that since the AD comes new lines all the way to the old frame rail pump that I may be better off to remove the pump (instructions say to simply disconnect it) and find a kit that runs the same 1/2" lines all the way to the engine. Question is, who makes a kit that is 1/2" from where the pre existing frame pump mounts forward? I know I have seen them somewhere and I believe they have the same quick connects that the AD style lines use
anyone? I dont see wasting the time to run 1/2" lines and or using the AD II if I dont have 1/2" all the way to the engine...
I wouldn't waste money on an AD anyways, people have those things fail left and right. I would just look at a fuel system from a site sponsor that uses a fuel lab or aeromotive pump, you will be way better off this way.
I got a brand new AD II from a guy that sold his truck for $350...I have read all the pump failures and have narrowed it down to the early AD products which have since been changed with much better results. When used with a sump kit it is reliable so Im going that route..just dont like that I disconnect the factory pump and leave it on the frame rail, and that the lines are only upgraded to the factory pump...
How much pressure does the AD kit put out? Personally I am not a big fan of either "fuel/air" separator systems (FASS or AD) their stand alone pumps aren't bad but their spin on filters are crap IMHO.
Anyways if the AD kit can make 65 psi of pressure or so you could just run 1/2 lines right up to a -8 AN Tee, from the T to the ports on the front of heads (you'll need a pair of -8AN (or whatever size you want to go with) to 1/8" npt fittings) and then through another set of 1/8 npt to XXAN fittings to the regulator and then back to the tank. You don't need to the 1/2 lines, the fuel necks down to 1/8" at the head and even smaller at the banjo but if you want consistency with the kit go for it. |
Yes the AD is good to 65 psi..I only wanted to do 1/2" line past the factory pump so I could just remove it. I really dont understand why the AD just says to disconnect the factory pump and leave it in its location..I really dont like that idea. my understanding of the kit when it was explained to me was that the AD was supposed to run with the factory frame rail pump which didnt really make alot of sense to me from the get go. I would think that the AD pushing fuel threw an unpowered pump would actually decrease pressure and cause problems..
You'll need to upgrade the wiring harness as well. That's the biggest problem with AirDogs.
