Need some info on getting my truck chipped. - Ford Powerstroke Diesel Forum
Old 01-10-2013, 10:01 PM
Need some info on getting my truck chipped. its a 2003 F-350 4x4 300,000km i am looking to get better fule mileage and more power if possible with out having to spend a ton.
Any info appreatieated.
Sent from my GT-I9100M using AutoGuide.Com Free App
Old 01-10-2013, 10:14 PM
i have the exact same truck with the same mileage. i've been looking at this over and over again lately
TS Performance 7.3L Powerstroke Switchable Chip (6 Position)
it seems cheap enough and i can't find anything negative....
Old 01-10-2013, 10:20 PM
Thanks
Old 01-10-2013, 10:26 PM
Winning DUHHH
TS chip returned with tw
Sent from my iPhone using AutoGuide.com App
Old 01-10-2013, 10:33 PM
pardon my ignorance but please explain.... "tw"? are you saying you had a TS chip and returned it for some reason?
Old 01-10-2013, 10:36 PM
Winning DUHHH
Yes, had a TS chip 6 position....sent it to tony Wildman for custom tunes
Old 01-11-2013, 05:05 AM
from the many many articles ive read, TW tunes are best. Im going to go with a single chip for my setup.
Old 01-11-2013, 01:32 PM
We can get you setup with a chip or programmer and some tunes if you are interested.
We have a couple different options as far as chips go.
We have the F5 chip(check it out HERE)
Or we have the F6 chip(check it out HERE)
Both chips will hold up to 16 tunes. The difference between the two is that the F5 has to be sent in to us if you want to update your existing tunes or receive new ones, whereas the F6 connects straight to your computer via USB to receive or update tunes. The F6 never has to be removed from the PCM once installed.
We can also get you setup with our Infinity if you are interested in going the programmer route. The Infinity will tune, monitor, read DTC's, run KOEO/KOER tests, play media, datalog, and much much more. It is available as a base unit where you can add what you want to it, or a preloaded version. You can check them out HERE
Let me know if you need anymore help or information.
Old 01-11-2013, 03:00 PM
Do not get the chip thats linked above; those are canned tunes. Get the php phoenix chip, less than $300. Will make your truck run like a dream.
Old 01-11-2013, 07:06 PM
Just an FYI, the above is referencing the linked TS chip.
DP Tuner tunes are not canned.
