turbo question - Ford Powerstroke Diesel Forum
Old 01-08-2013, 03:41 PM
turbo question
im looking at putting a new turbo on my 99.5 7.3 i have a s400 turbo new for my 60 series detroit will that fit in place of the s366
Old 01-09-2013, 11:08 AM
The 60 series turbo will more than likely be a t6. It'd help if you posted what turbo it is tho, there are a lot of 400 series turbos.
Old 01-09-2013, 11:12 AM
It's the k31 turbo it is a t6 flange but I was going to buy a kit and switch the t4 flange out with a t6 flange
Old 01-09-2013, 12:04 PM
I've run an S468 for awhile, but it has a T4 mount.
Call Jake at Irate. He can probably whip you up a T6 mount for fairly cheap.
Old 01-09-2013, 11:18 PM
The k31 is a little different turbo, i haven't seen this run on a t4 flange. Only flange I've seen this on is a t4i or a t6, you may be able to sell it. It's a billet wheeled 71mm I want to say. I don't think there is a t4 flange for it tho, I may be wrong just haven't seen it. If you are looking for a 366 I have one, it has a t4i housing on it right now but it can be swapped.
Old 01-10-2013, 05:08 AM
What do you want for it
Old 01-10-2013, 11:22 AM
Would you be up for a trade? I'll have to call a guy I know and make sure he can get the housing for a k31 first if we were to go that route.
Old 01-10-2013, 11:31 AM
prob let me double check and make sure it is a k31 i would hate to say the wrong one
Old 01-11-2013, 09:43 AM
Also is it a vband compressor outlet? Is it internally wastegated?
Old 01-11-2013, 01:34 PM
ok i got to look at it today and i found out its a gta42 internal actuator turbo with a vband compressor outlet
its had 5 days of run time on it took it off for a bigger turbo on the detroit
