Injectors + tune=who???
I'm shopping around looking for a set of injectors that I can toss in now, and down the road possibly buy a 38r! I would like to stay in the 400-450hp range! I'm not real interested in head stud or springs so... The question is which brand injector and who is perfered for tuning???? Mods are in my sig!!! And I have gauges!!! And I all ready have a dp tuner, but I could care less if I buy another brand tuner!
We can get you setup with some Full Force injectors. I would say stage 1's would be perfect for you.
If you buy the injectors from us and you bought the chip directly from us then we will update your tunes to match with the new injectors for free. Let me know if I can help you out. |
come on guys i want opinions, who's injecters and who's tunes??? i've read good feedback about swamps, im thinking probably in the neiborhood of "stage 1" injectors?
You got an opinion. Give Justin a call. Full Force Injectors are top notch and Jody will take care of you.
I wouldn't waste my time with a Stage 1 injector, personally. Stage II's or small hybrids. Stage II's with a 38R will make a great combo. |
Can I run the stage 2's with a stock turbo for a while and still tow my race car? Are there any upgrades I need that i dont have before running stage 2's?
Stage 2's will require a built trans, studs, RR with fuel bowl delete and I'd get valve springs.
A 38r will work but not well..get a modded H2e will out flow and outlast a throwaway 38r turbo. Stage 2's and a stock turbo towing...not very well esp with the Banks stuff. As stated..stick with FF stage 1's and a 38r. |
Stock turbo, no RR, no valve springs, and no head studs with Stage 2 Full Force Injectors. Any kind of a RR, including Riffraff's FRx can't hurt. Prevent that excess air from going through the injectors. I did have to rebuild the transmission. I towed a 5k boat all over and towed a 12k trailer over the passes multiple times where I live. The EGT's will climb in OD, but I also have 3:73 gears with 37" tires. Shift down and enjoy. That being said, the turbo will not last forever with those injectors. Mine surged bad at times and the bearing was going out when I swapped to a t4 style turbo. In my opinion, the only reason to go with Stage I injectors is if your stock injectors are worn out. You'll spend all that money and get very little seat of the pants change. You won't be happy. Like I said before. Get the Stage II's or small hybrids. |
Id personally get hybrids and have them tuned back. If you want more later, you just need to have the tuning readjusted.
I say fullforce injectors, but swamps are great too. It sounds like Dp's offer will save you money. I personally like a ts style chip with php tunes. Beans has great tunes as does tony wildman. There are many options and many threads just like this one. You could check them out and see what routes people went with. There will be too many different opinions and you will end up with an unclear answer. Best ofluck with your choice |
Thanx everyone for your input. I have done a lot of reading on this subject and u guys help out a lot ! Thanx!
