ts 6 position question - Ford Powerstroke Diesel Forum
Old 01-02-2013, 11:18 AM
so i found a used ts 6 position chip on craigslist. its from an 01 f350. can i just plug this into my 02 excursion or is it vin locked or anything? want to make sure before i spend 150 on a part i need to spend more money on to use. thanks guys.
Old 01-02-2013, 11:20 AM
A lot depends on how the chip was set up, built trans, more fuel, etc.
You'll want to have the same PCM code as the chip was tuned for.
If none of this matches your set up, you'll have to send it off to have it tuned for your vehicle.
Old 01-02-2013, 11:24 AM
ok thanks alot. ill try and get more info from the guy and see if he has a clue as to what pcm he had. oh and where are my pcm numbers so i can check mine as well?
Old 01-02-2013, 11:25 AM
These are instructions on how to install, but the # is on the side of the pcm. You have to take it out to read them.
Welcome to guzzle's DP Tuner's Chip Installation Web Page
Old 01-02-2013, 02:49 PM
The chip wasbon a 01 f350 and i have a 02 excursion but he doesnt know his pcm code
Old 01-02-2013, 03:09 PM
If you take a mirror, you can actually read the PCM code pretty easily. Look on the fender side of the connector, under the hood below the Master Cylinder, with a flashlight reflected into the mirror. No need to disconnect anything.
It's in the largest font, 4 characters, mostly letters (my '02 is VDH4)
Old 01-02-2013, 03:12 PM
Its not the we cant read it. He doesnt have the truck anymore
Old 01-02-2013, 03:27 PM
Plan on getting custom tunes made specifically for your truck(mods/pcm) then.
