T4 turbo now a weird sound
Hey ever since i did my T4 turbo the turbo spools and makes a wind sound almost and i dont know it that is right. it spools up and is hissing like a turbo then i makes a different sound when it gets to about 20-30 psi and makes this weird sound and it kinda feels like it looses power i dont know could it need to be retuned for this turbo?
Well, I do know that past the whistle, a turbo will start making a large air sucking (wind) sound because it is actually doing that! Lol.
Now as far as slowing down, not sure on that. Might be running out of fuel. |
probably the wastegate, do you have a boost fooler?
that weird noise would most likely be the waste gate opening up. what turbo are you running? internally gated or external gate? My turbo Camaro makes a different weird noise when my gate opens up on 10# when i'm running pump gas, and even with my external gate plumbed back into the down pipe it makes a very recognizable "exhaust leak" sound inside the car
Turbo sounds completely different. It sounds wicked!! I love me Bell HFSB. Like others said, wastegate or no? I don't have one so I cant say too much. But I'm pretty sure you gotta adjust it too your needs
Are you running stock injectors?
yes i am running stock injectors but it is a s366 turbo from irate diesel and im not sure if it is internally wastegated or not at all i dont think it is
Could be a split boot. Can you pressurize your intake side and check for a split/cracked boot?
What kind of sound is it making?? I can hit 35 psi with mine and it keeps pulling till I gotta shift. And theres no need to get a retune. Not until you swap injectors |
How much did it run? Where did you get it? What else will i need to install?
I was going to run a 38r but am looking at other options |
