TURBO SCREAM - Ford Powerstroke Diesel Forum
post #1 of 14 Old 10-31-2007, 10:18 AM Thread Starter
What u talkin bout willis
REDPOWERSMOKER's Avatar
Send a message via AIM to REDPOWERSMOKER Send a message via Yahoo to REDPOWERSMOKER
TURBO SCREAM
HOW CAN I MAKE MY TURBO SCREAM I AM WANTING IT TO BE LOUD SO ALL MY BUDDIES WITH CUMMINS OR OTHER JUNK CAN DROOL OVER MY SCREAMING TURBO I DONT WANT IT TO BREAK BUT I DO WANT IT TO WHISTLE REALLY LOUD
2005 F-250
Tuned by Innovative
Deleted by Performance Machine
Coolant filter (Orderd) by Performance Machine
REDPOWERSMOKER is offline
post #2 of 14 Old 10-31-2007, 10:20 AM
Desert Shield/Storm Vet
vitalidle's Avatar
Is that an early 99 or a 99.5.
2002 F-250 4x4 EC, SRW, SB
Auto 93,000 miles
DP Tuner F5
ATS Compressor and 1.0 Exhaust housing high flow back plate
Turbo Back 4" Silverline Exhaust Mbrp Muffler Delete
Isspro Trans,Pyro,Boost Triple Pod
Fumoto Oil Drain Valve
AIH Delete With Boost Fitting
vitalidle is offline
post #3 of 14 Old 10-31-2007, 10:22 AM Thread Starter
EARLY 05/98
2005 F-250
Tuned by Innovative
post #4 of 14 Old 10-31-2007, 10:26 AM
vitalidle's Avatar
Hmm well that makes it a bit tougher! Probobly a D66 turbo as you already have the wicked wheel as a stock compressor wheel and you don't have the foil on the intercooler pipe. Straight pipe your truck if you haven't already
Auto 93,000 miles
DP Tuner F5
post #5 of 14 Old 10-31-2007, 10:32 AM Thread Starter
I JUST FOUND OUT ABOUT THE FOIL AND MINE DOES HAVE IT ON THERE BUT WILL BE REMOVED AS SOON AS I CAN GET DOWN THERE AND THE EXHAUST IS A 4" TURBO BACK BUT IT DOES HAVE THE MUFFLER SO I NEED TO FIND A PEICE OF PIPE TO REMOVE THE MUFFLER
2005 F-250
Tuned by Innovative
post #6 of 14 Old 10-31-2007, 10:34 AM
vitalidle's Avatar
Oh okay I was thinking the early 99's didn't have the foil. Learn somthing new everyday. What brand exhaust is it? You will definately notice a huge difference without the muffler for turbo whine!
Auto 93,000 miles
DP Tuner F5
post #7 of 14 Old 10-31-2007, 10:37 AM Thread Starter
WELL EVERYBODY ON HERE SAYS THAT THE EARLY 99 DIDNT HAVE THE FOIL BUT MY DOOR SAYS BUILD DATE OF 05/98 AND I GOT FOIL ON IT AS FOR THE EXHAUST I DONT KNOW MY OTHER HALF BOUGHT IT OFF ONE OF HER FRIENDS THAT WENT TO IRAQ AND SHE DOSENT KNOW IS THERE A MARKING ON IT OR ANYTHING THAT CAN TELL ME WHAT IT IS
2005 F-250
Tuned by Innovative
post #8 of 14 Old 10-31-2007, 10:38 AM
CSIPSD's Avatar
Some have the foil some dont, If you went in for service work when it was in warranty, they would swap it on...
There is not much you can do to change the sound, other then remove the muffler.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #9 of 14 Old 10-31-2007, 10:40 AM Thread Starter
OH OK WELL I GOT ANOTHER QUESTION WHAT IS A ZOODAD??
2005 F-250
Tuned by Innovative
post #10 of 14 Old 10-31-2007, 10:41 AM
vitalidle's Avatar
Crawl underneath and see if the muffler has the manufactur markings on it. You should be able to buy a muffler delete pipe for about 50 bucks and it will slide right in where the muffler is.
Auto 93,000 miles
DP Tuner F5
