Fuel Bowl Delete Complete - Ford Powerstroke Diesel Forum
Old 10-30-2007, 09:15 PM
John Wood Nut Swinger
I got the project done. I deleted the fuel bowl(thank you Dennis at ITP), regulated the return and added a higher flow fuel pump. I hope it works good. I will keep all updated on how the Walbro 255hp pump works. I am taking it to the track next Wednesday night to see how it does and how it holds fuel pressure under WOT. I will test it a bit tomorrow on the way to work now that it is finished and running.
The rest of the pics are here: Fuel Bowl Delete pictures from friends & fun photos on webshots
Old 10-31-2007, 02:34 AM
BIG TRUCK, SMALL DRIVER
Looks sweeeet!!!
How long did it take?
Old 10-31-2007, 08:45 AM
Dennis's Bowl delete is awesome! Can't wait to do mine..
Old 10-31-2007, 09:48 AM
Fuel pressure at idle is set at 60psi. At WOT it drops to 58spi. I am very happy with the pump. Not bad for a $120(delivered) Walbro pump.
Getting all the parts the first time was the hard part. I am a DIY guy for the most part so most of this was made by me. The fuel pump fitting I bought with the pump was bad so I had to find another one. Then the fuel Y I had bought was too big so half way through I decided to order the ITP delete block. It took a little over two weeks to complete it. Total work time would only be about 4 hours.
Old 10-31-2007, 09:52 AM
Thats Mr. Oil Leak.....
Did you add another filter after the pump or are you running a pre pump filter? I've been thinking about doing this as well (already have the reg return system) to get the fuel bowl out of the way of everything else.
Old 10-31-2007, 09:57 AM
What u talkin bout willis
Send a message via AIM to REDPOWERSMOKER Send a message via Yahoo to REDPOWERSMOKER
WHAT DOES DELETING THE FUEL BOWL DO???
Old 10-31-2007, 09:58 AM
for the most part I think it just free's up the clutter. I know for people like me and strokin and others that have dual hpops and everything else it gets jam packed pretty easy.
Old 10-31-2007, 10:04 AM
Send a message via AIM to rednek01 Send a message via Yahoo to rednek01
I that and it just looks awesome and would all the dodge and chevy guys who looked in the engine bay :fawkdance:
Old 10-31-2007, 10:55 AM
I have a 12mic pre pump filter/water seperator(15gpm flow rate) and a post pump 2mic filter(12gmp flow rate). Take a look at the pics of the setup. The link is at the bottom of my first post. napa filters and filter bases. Less than $100 for the filters and bases. Pump was $120.
Old 10-31-2007, 11:17 AM
oh geez.. I didn't even see that the first time.
