I'm not sure if that post is an argument for or against the OP.
But if the above post says that by physical dimensions(the top is 7 times larger than the bottom), the injector piston multiplies HPOP pressure(say 3000 psi) up to 21,000PSI(7 times 3000), and that fuel pressure is not a factor in the mathematics what-so-ever, then yes... I agree. |
The fuel is what gets multiplied. I made my Samsung SGH-I997 send this. |
Ok, i found this explanation on line and i think we are all saying the same thing just differant ways of explaning it. "The computer controls how long the injector solenoid is energized (pulse-width, or time on in milliseconds), but it also determines the pressure of the fuel being injected by controlling the pressure of the oil (IPR duty-cycle, or the percentage of time on vs. off--AKA dwell) in the cylinder heads. The computer determines this based on engine load and driver demand by monitoring various sensors. Since the cavity at the top of the intensifier piston is seven times the size of the fuel cavity at the bottom, fuel is injected at a pressure seven times that of the computer-controlled oil pressure--oil pressure 3000 psi = injected fuel pressure 21000 psi. Due to the high oil system pressures, the spring which closes the poppet valve once the injector solenoid is deactivated has to be very strong--and because of this, the solenoid needs to be 110 volts. Once the poppet valve is closed, spring pressure returns the injector to its normal state and the oil is exhausted into the valve cover area to return to the sump." (Blackclouddiesel.com)
Bottom line 21,000 psi is the maximum pressure the fuel is injected, it is a direct result of the maximum oil pressure of 3,000 psi. (3,000 x 7,000 = 21,000). Increasing fuel pressure will do nothing other than cause premature wear on the fuel system. |
:And that is based on using max ICP. At those high pressures, going from 55 to 105 is such a negligible amount, no one really takes it into account. It technically will yield higher hpf injection, but that's splitting atoms I made my Samsung SGH-I997 send this. |
jesilvas, The HPOP doesn't put out 3,000PSI all the time. 3,000 is the maximum. HPOP out is variable from something like 650 up to 3,000. The ECM doesn't operate the injectors(spool valve) until around 550PSI. From there, depending on total fuel required for demand and RPM, the ECM varies ICP( pressure from the HPOP) and the amount of time between the open 48v pulse and the close 48v pulse being applied to the respective coils that move the spool valve to and fro. |
^ I think you're starting to talk about 6.0 stuff now. 7.3s use a little more than just 48v
Sorry, make that 110v or 120v for a 7.3, 48 -58v for a 6.oh
I poked, then stated that was max icp I made my Samsung SGH-I997 send this. |
wow
well now that thats all hammered out and their seems to be a solid consensus hope this helps the op out i am sure that all involved were not intending to hijack this thread but i know i personnaly didnt want to read your next thread about your fuel system failure of some sort given what has been discussed i think it can be simply capped by stating
the fuel pressure feeding the injector only plays a factor if theirs air in your fuel so a good quality filter/ regulated return system should safely reap the same benifits of 115 psi of fuel except that your fuel pump will live much longer to tell the story four pages later i hope you have achieved something from our bickering |
